Passenger Side Heat
Is there some kind of "mode" that needs to be turned on that enables an adjustment to the heater on that side. I know on the driver side, when I make an adjustment, I can see the thermostat adjustment. Yet, when I make the adjustment for the passenger side, nothing appears and there is nothing but cold air coming out.
Anyone have any ideas? Thanks in advance.
http://forums.corvetteforum.com/c5-g...ed-advice.html
You can use the search function and look for posts with (heat, or blower acutator), there are a lot of possibilities, many of them are not hard to correct.
Good luck
