corner lights questions
Old Feb 9, 2010 | 08:47 PM
Badd LS6's Avatar
Badd LS6
Default corner lights questions
ok so im going to be swaping out my corner lights..i was just curious how they pop out..i know i can figure it out but since my baby is currently sleeping under the cover i dont wanna disturb it ..
these are what im gonna be putting in
http://cgi.ebay.com/ebaymotors/97-04...Q5fAccessories
also i was wondering if they are gonna appear just like this with the glow line along the bottom of the housing or are these a different pair ..(not gonna use blue bulbs tho)
http://www.shop.jwmotoring.com/produ...1&categoryId=4
Old Feb 9, 2010 | 09:57 PM
2EZ 2SPD's Avatar
2EZ 2SPD
I have the same ones from ebay and they are different from the ones JWM has that is a light strip in the bottom of his. I tried to post some pics of a drawing to do this but I couldn't get it to work sorry. It's easy I did mine about 15 mins each.
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Old Feb 9, 2010 | 11:52 PM
Badd LS6's Avatar
Badd LS6
thatll just about do it..thank you 2EZ 2SPD
Old Feb 9, 2010 | 11:57 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Those bulbs are white.
If you want the led strip we do those for $87 if you send us your corners.
We have several options for them as well which allow you to run them with the DRLS if you want.
Old Feb 10, 2010 | 06:47 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Badd LS6, I can only say that if I can do it you can do it. Changed mine last month using JW's clear/black w/led strips and used led bulbs.
Old Feb 10, 2010 | 11:33 AM
Badd LS6's Avatar
Badd LS6
len90vette haha im sure its not too hard just was being curious before i tear it all apart and take twice as long..BTW how u like the clear n black corners with led strip on ur silver Z?? got any pics by chance ? thanks brother
Old Feb 11, 2010 | 10:32 AM
clif's Avatar
clif
I got a pair of the clear corners from JW, with the optional LED strip in the bottom. I even had JW tint them for me, so I guess they are not clear anymore? Anyway, I also bought the switchback LEDs fromn JW, and let me tell you, these are so SWEET looking! JW provides only the best quality parts!
Old Feb 11, 2010 | 10:54 AM
JW Motorsports
Banned Scam/Spammer
Thanks Clif!
Old Feb 11, 2010 | 11:02 AM
DeeGee's Avatar
DeeGee
Heres one I posted earlier. the pics may help:
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Removal Procedure
Notice
Tighten
Tighten
To corner lights questions
