C5 Convertable antenna
Old Feb 10, 2010 | 10:33 AM
farout1's Avatar
farout1
1st Gear
Default C5 Convertable antenna
Snapped off the ugly stock "10 foot" auto antenna sunday night. Any replacement shortys for Convertables. All I see is for hardtop coupe. Also can I fix with replacement mast?
Old Feb 10, 2010 | 10:36 AM
PhatZ06's Avatar
PhatZ06
http://forums.corvetteforum.com/c5-z...y-antenna.html
I just bought this one...highly regarded.
Old Feb 10, 2010 | 01:40 PM
msgvert's Avatar
msgvert
Just a thought - can a power antenna be shortened and still retract properly?
Old Feb 10, 2010 | 02:02 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
go here: http://forums.corvetteforum.com/c5-g...enna-woes.html
look at post #3 for info on mast replacement
Old Feb 10, 2010 | 05:10 PM
DeeGee's Avatar
DeeGee
You could just replace the mast. Its a 5 minute job and the parts are available on E Bay
How To Replace a Defective Telescopic Antenna
Now this is a simple mod and the OEM assembly with motor is $130+. You'll know you have the problem because the antenna won't fully retract
Parts:
Adjustable wrench
GM OEM Power Antenna Replacement ($13 E Bay).
Make sure the antenna is fully retracted and that the radio is off
Remove the antenna mounting nut located on the base of the mast on the outside of the car. If the mast is bent it may be necessary to cut off the old mast). If you can't all of the plastic cable out as one piece, (sometimes the plastic gets really hard and breaks into pieces then falls down into the motor), you can just pull the motor after you have pulled the mast out and get all of the pieces out. To do that you'll need to take out the outer right turn signal housing.
Turn on the radio and pull out the old mast and serrated cable completely out of the antenna motor. (Note which way the serrations on the cable are facing)
Feed the serrated cable of the new mast into the antenna hole and stop when resistance is felt. (about 12”). Make sure the cable is fed in with the teeth the same way the old cable came out.
Turn the radio off to lower the antenna until the serrated cable catches.. You may have to cycle the antenna a few times until the cable catches the gear mechanism and retracts into the antenna motor.
Replace and tighten the antenna nut into the mast base.
Turn on and make sure that the mast fully extends without binding. Clean the surface of the antenna to remove any adhesive etc.
10 minute job.
If you encounter a stuck mast here’s advice from the mast vendor:
You see the new "Retaining Sleeve" (silver, 2 inches or so, with slots) on the shaft of the new antenna mast, the original one is most likely a little corroded/frozen into the shaft of your antenna No problem : You are in need of what I refer to as the "snap and tap" technique of mast removal
Turn radio on and let cycle to as much extension as is currently possible
Take hold of the thickest metal mast section (closest to fender) with you thumb and forefinger about 2-3 inches above the top of the antenna shaft hole
Push the thickest mast section into the shaft (as much as it will go within that 2-3 inches)
Hold tightly with thumb and forefinger and Snap your Wrist upward.....you will here the mast bottom "tap" the bottom of the frozen in place retaining sleeve (what this is all about) Repeat this over and over again In-Snap-Tap-Repeat Short Firm Bursts of Energy Focusing the energy blow to the point of the tap This will free the retaining sleeve little by little till it comes out completely
Old Feb 11, 2010 | 12:03 PM
waupachino's Avatar
waupachino
I would just replace the Mask. After you do that, if your looking for short, just unplug the power connection to the Antenna. I did this to mine and still get great reception without the 10Ft Mask.
To C5 Convertable antenna
