New rear bumper...should we make it?
Old Feb 13, 2010 | 04:31 PM
c5blkvetteguy's Avatar
c5blkvetteguy
I vote for a longer, thinner LED 3rd brake light.
Old Feb 13, 2010 | 04:34 PM
SCM_Crash's Avatar
SCM_Crash
That's a good idea.
Old Feb 13, 2010 | 04:38 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by SCM_Crash
I personally don't like the "wing" look on Vettes... I had one on my Z06 when I first got it and it didn't look good from most angles.
Normally I agree. Usually the wings
a) don't line up well with the rest of the body lines
b) are not very functional
c) look kinda goofy.
The problem with top-mounted rear spoilers is that they produce downforce by significantly disrupting airflow over the rear of the car. This creates a significant amount of drag as well as a large turbulant wake behind the car that results in a low pressure area causing even more drag.
However, I think it's possible to make a wing that' subtle yet effective in it's purpose. The idea of a wing is that it allows the body lines to remain effective b minimizing the low pressure wake while still providing significant downforce at high speed. An ideal wing would be an on-the-fly adjustable based on speed, but that's a long way away for the C5.
Old Feb 13, 2010 | 05:21 PM
SCM_Crash's Avatar
SCM_Crash
I've seen them actually:
http://www.breathlessperformance.com...arbonFiber.asp
These are pretty universal, but will definitely go on a C5.
Pretty interesting...
Old Feb 13, 2010 | 05:54 PM
HowlinC5's Avatar
HowlinC5
Well if I ever decide to take up drifting I know where to get a spoiler now!!
Old Feb 13, 2010 | 10:16 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by TheRadioFlyer
Sounds good.
What if you extended the lines of the bumper's sides to form the vertical component of the wing itself:
Subtle, VERY strong and functional. With the proper inverted airfoil cross section. it would be very effective at high speeds without significant drag.
no way man.
Old Feb 13, 2010 | 10:34 PM
Castrellon's Avatar
Castrellon
Aren't wings only functional above 125 MPH?
Old Feb 13, 2010 | 11:29 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Originally Posted by zeevette
I'd say there's room between the giant spoiler on the Tigershark, and the Spectre-Werkes fairly subtle lip. Just don't spoil it with those god-awful ricer diffusers, or the narrow exhaust pipe opening that requires custom catbacks.
Old Feb 13, 2010 | 11:57 PM
02MillenniumVette's Avatar
02MillenniumVette
I posted these in the thread created several months ago when you wanted to do a diffuser for a C5. Id love to see a TS rear bumper with a diffuser built into it. These are obviously photochopped but the real thing would look bad @$$.
Old Feb 14, 2010 | 02:51 AM
striper's Avatar
striper
Doesnt Caravaggio make a couple wings? Correct me if im wrong. You talking about the one that wraps around the sides (so to speak)[/QUOTE]
Yes, the one that wraps around the sides.It was designed by John Cafaro when he was designing the C5. It was originally supposed to be a GM accessory. Even though it is an add-on I really like the way it looks. If it was an integral one-piece rear bumper, maybe with a longer, thinner CHMSL molded in, it would look perfect. I was wondering how smooth the rear would look with the lettering removed. A diffuser wouldn't look bad if was a little more subtle than some aftermarket ones I've seen.
Old Feb 14, 2010 | 03:13 AM
adrift's Avatar
adrift
Originally Posted by 02MillenniumVette
this is what the tigershark bumper needs. something to finish off the bottom where is seems to just go on forever.
I like.
Old Feb 14, 2010 | 05:07 AM
SCM_Crash's Avatar
SCM_Crash
No... Actually, they can be quite functional around 50-80MPH. Depends on their angle though. Taking corners and applying down force to the inside half of the car makes a huge difference in cornering; allowing more rubber to stay in contact with the road and allowing for faster speeds through the turns.
Old Feb 14, 2010 | 09:38 AM
  #33
GB Vette's Avatar
GB Vette
CF Over the Hill Member
Cruise-In IV Veteran
CI-4 Car Show Winner
Cruise-In VI Veteran
CI-6 Car Show Winner
Cruise-In VII Veteran
CI-7 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-08-'09
NCM Ambassador
It would probably look somethinglike this if you did
Old Feb 14, 2010 | 10:15 AM
  #34
hattitude's Avatar
hattitude
Originally Posted by meflyfrc
I agree with the Caravaggio style spoiler molded in. But, I like the Corvette lettering.
I Like the look of the C5 rear end, but I would like a spoiler that is not just taped on.
I would be very tempted to purchase something that has the molded in spoiler. But for me, anything else that differs from the stock rear (modified back-up lights, brakes lights, diffuser, etc) would seriously reduce my chance of buying such an item.
Just my 2 cents....
Old Feb 14, 2010 | 11:44 AM
  #35
matt3310's Avatar
matt3310
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
2016 C7 of the Year Finalist
2015 C6 of the Year Finalist
Cruise-In X Veteran
St. Jude Donor '09 thru '19
I say go for it!!! I think it would look great!!
Old Feb 14, 2010 | 11:54 AM
  #36
robbyd831's Avatar
robbyd831
how bout a zr1 style spoiler for the c5
Old Feb 14, 2010 | 02:03 PM
  #37
02MillenniumVette
They already make one.
http://www.corvettecreationz.com/rear-spoilers.html
To New rear bumper...should we make it?
Old Feb 16, 2010 | 12:20 AM
  #38
chrisj's Avatar
chrisj
St. Jude Donor '12
I just bought a SW a couple weeks ago. If you had one that was slightly more aggressive than the SW, but not as much as the TS I would have gone with it.
Good luck finding the majority on this topic.
chris
Old Feb 16, 2010 | 01:26 AM
  #39
matt3310's Avatar
matt3310
Cruise-In X Veteran
Id love to see a caravaggio style spoiler made in with a diffuser at the bottom!!!!
Old Feb 16, 2010 | 02:08 AM
  #40
kingrobby25's Avatar
kingrobby25
I really like the idea of a diffuser, but NOT any of the current ones being made right now. It would have to seamlessly mold into the current rear bumper cover, without having the look of being stuck onto a stock bumper.
