Locked steering wheel
Old Feb 13, 2010 | 06:52 PM
corvettebuddy's Avatar
corvettebuddy
Default Locked steering wheel
HELP HELP 1998 Corvette Conv Low miles never set out in rain etc. Jumped into the car to go out. Car started and was running then on the cluster it said turn key off for 10 seconds. I did it. Then the column Wheel went to the locked position. No horn sounds nothing seems to be wrong. Disconnected the batt tried everything I could think of. { Nothing} Motor runs but column is locked not to move. Keeps saying that the column needs serviced. I do get the take the key out for 10 sec also. Battery is very good and on the charger now to eliminate that problem. Any help would be appreciated. Thanks 309-472-2001
Old Feb 13, 2010 | 07:46 PM
Bellboy's Avatar
Bellboy
You have been bitten by the infamous column lock problem on these cars. Check for blown fuses in the fuse panel under the floor toe board on passenger side. Pull the carpet back from under the dash and you will see the fuse panel. I had a fuse blow in there on my C5 once and, if I remember correctly, it was a 10a fuse in position 25.
Sometimes the steering column can be made to unlock by turning the key on and shaking the steering wheel back and forth left and right violently. That may break loose the locking mechanism so it will unlock.
When you do get it working again, it would be a good idea to install the column lock bypass unit to do away with that problem.
There was a recall on these cars also that did away with the locking steering column. You might see about getting that done.
Old Feb 13, 2010 | 07:53 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Check this out......... C5 Column Lock FAQ
Old Feb 13, 2010 | 08:17 PM
corvettebuddy
Default Fuses Dash says{ service steering column}
Dash says Service steering column. Checked all the fuses under the pass side panel. All OK whats next. Thanks
Old Feb 13, 2010 | 08:28 PM
Carcass's Avatar
Carcass
Shaking the steering wheel may and hoping for the best may be the only option you've got at this time --IF YOU DO get it unlocked,you need to leave the key in the switch so it doesn't lock again till you get a Column Lock Bypass installed (hopefully,you've got 2 keys for the car)
A CLB was the very first mod I did when I got my 98
Old Feb 13, 2010 | 08:39 PM
ronssito's Avatar
ronssito
Installed my CLB in ~2 hours last month ... peace of mind!
Old Feb 13, 2010 | 11:15 PM
Glennm27's Avatar
Glennm27
Order a Column Lock Bypass kit and install it immediately. In the kit you will get what's needed to first unlock the column... THEN install the CLB.
If you've had the GM fix done by your dealer then you must have a manual trans car. The GM fix is NO guarantee in manuals.
GET the CLB ASAP
Old Feb 14, 2010 | 08:01 AM
RSchleder's Avatar
RSchleder
Buddy-- a CLB is definitely in your immediate future. $60 and 20-30 minutes and you're in good shape, Just gotta get it UNLOCKED first!
Old Feb 14, 2010 | 08:14 AM
corvettebuddy
I'm trying everything I know of to get it unlocked. I got the service manual GM for this year and giving it my best shot.
Old Feb 14, 2010 | 09:22 AM
Mike99FRC's Avatar
Mike99FRC
Try shaking it back and forth to the left and right for a bit. It happened to me. I was able to break it free. Just gotta be patient. Then get that CLB!!! Good luck.
Old Feb 14, 2010 | 10:19 AM
Han Solo's Avatar
Han Solo
Corvette Buddy,
Turn off and remove key for 10 seconds or more. Then turn the wheel hard to the right while turning the key on. It should pop loose. After that remember to have the wheels straight when you turn the ignition off.
Old Feb 14, 2010 | 10:26 AM
itzza427's Avatar
itzza427
If by any chance your car HAS NOT been to the dealer,,,by all means,,,,DO NOT TAKE IT THERE!!!!! For peace of mind install a CLB yourself!! If it has the factory fix,,get the factory fix "K-harness" WILL FAIL,,,it is a case of WHEN it will fail,,,not if it will fail. One guarantee you can depend on,,,the K-harness will fail,,,causing this very problem. The fact that your column DID lock would indicate that #1 I may not have had the recall fix or #2 if it did it may have been an early recall before they removes the locking pin that became part of subsequent fixes along with the programmed fuel shut off. The later fixes CREATED more problems than they fixed with the computer reprogram.My two cents, Me,,,I removed the K-harness,,installed a CLB and have been confidently motoring for a year and a half and about 15,000 miles !!
Old Feb 14, 2010 | 10:36 AM
corvettebuddy
Thanks for the advice. I will install the cbl when I get the column to unlock. Now its locked and there is nothing that I have done so far to correct it but I will keep trying Thanks
To Locked steering wheel
