Relocating hvac controls
Old Feb 19, 2010 | 08:20 AM
bowtiebubba's Avatar
bowtiebubba
Default Relocating hvac controls
Has anyone moved the hvac controls to the ash tray area? What would have to be done on the inside rack to do this?
Old Feb 19, 2010 | 09:42 AM
ICULUKN-C5's Avatar
ICULUKN-C5
its a popular mod for stereo people wanting to run a double din...
maybe check the audio forum
Old Feb 19, 2010 | 05:14 PM
bowtiebubba
ttt
Old Feb 19, 2010 | 06:40 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
why exactly are u moving it? as far as on the inside there is a metal brace that has to be cut
Old Feb 19, 2010 | 07:14 PM
bowtiebubba
Im doing a gauge panel across the top of the bezel, then a double din pioneer , & the hvac on the bottom. I just dont know what needs to be removed on the rack inside to do this.
Old Feb 19, 2010 | 07:39 PM
dobewillie's Avatar
dobewillie
Good luck with your project
Old Feb 19, 2010 | 08:14 PM
bowtiebubba
anyone?
Old Feb 19, 2010 | 08:54 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
The controls will be loweredall the way to the bottom where the ash tray is now.
Has anyone else installed the hvac controls here to help out with some info. I have seen it done just dont know what was involved on the backside
Old Feb 19, 2010 | 08:55 PM
Spoon83's Avatar
Spoon83
I did it and it fits with no problem. Once you pull your center console, remove the center brace under the stock radio by removing 4 rivets which hold it in place. Now you can move the HVAC controls to the ashtray area. You can drill new mounting holes but I would recommend using Velcro to hold it in place. Once you put the center console back, it will push against it and keep the controls in place. I am currently using that method and it has been fine for a couple months now. Also check the audio section for more info. Hope this helps and good luck...
Old Feb 19, 2010 | 09:33 PM
0Double D Mods
Former Vendor
Hi is going all the way down Jarek. Not like the normal DD lowering.
Old Feb 20, 2010 | 09:21 AM
bowtiebubba
I know i have seen this done by someone on here before. Looking at the rack i would say that bottom brace is going to have to come out also.
Old Feb 20, 2010 | 11:52 AM
Patches's Avatar
Patches
Shouldn'd be a problem as the A/C controller is consderably shallower than the head unit and there is lots of room in the stack near the bottom. I recently did a dd Kenwood HU installation and cut both brackets out to make room for the HU. I had to move the A/C controller down about 3/4" to line up with the new dd bezel from Double D Mods. You will need to do some trial fitting to make sure you have the clearance you need if you go very low - the ashtray screw hole mount may be in the way if you're at the very bottom but it should not be a problem to adjust everything to your new location.
Here's the stack before cutting . . .
. . . and after cutting the support brackets out.
The rivets that hold these brackets in are a bear to drill out so be ready with hardened bits. I also used a right-angle drill adapter.
I reinstalled one of the brackets for extra HU support.
Old Feb 20, 2010 | 03:04 PM
Jistari's Avatar
Jistari
If you're just talking about moving the HVAC unit down to where the ashtray goes, I did mine and didnt have to cut anything metal behind the bezel, just bent the ashtray brackets back so the HVAC fits.
[IMG][/IMG]
You will have to cut the bezel so the HVAC lays flat against it (the ashtray is canted). And shim the screws on the right side so it angles a little toward the driver (thats how the opening is on the bottom). Add a small piece of weather stripping across the bottom of the opening where the bezel meets the HVAC face (very small but visible space if left out)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Feb 20, 2010 | 05:19 PM
bowtiebubba
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
You have exactly what im looking for. I went ahead and cut the ash tray brackets out today.
Old Feb 20, 2010 | 05:28 PM
0Double D Mods
Former Vendor
your normal hvac section will be lowered all the way down so it will be same exact opening size too
Old Feb 20, 2010 | 10:10 PM
MySR71's Avatar
MySR71
It takes a bit of trial and error to figure out how much plastic to trim behind the flip up door. The fit is mostly dependent on how much time/effort you put into it. If you decide to drill the HVAC contol panel on the sides to bolt it down, it drills no problem. I was concerned that the plastic would be too brittle and crach. It wasn't a problem though.
I removed the cig support brackets as was mentioned above. It seems to me that a little more trimming was required of some of the plastic ribs on the back of the plastic surround.
I removed my radio to put my data acquisition display in its place. I relocated the HVAC controls a year later to install a bank of switches. Fit and finish aren't critical to me. Some day I'll go back and clean it up.
Old Feb 21, 2010 | 11:33 AM
Jistari's Avatar
Jistari
Dont know wht you are using to print the lables on those switches but you could either print them all at once on one sheet and apply the whole sheet to the panel. Although you would have to settle for a light grey backround (Like the HVAC) with black letters (not sure Ive seen a way to print white letters on an inkjet, could be wrong though). Or if using a lable maker just print each row as one strip to even them up :-)
Love the "cockpit" look you have going there All you need is the shrouded Master Arm switch for the weapons system.
To Relocating hvac controls
Old Feb 21, 2010 | 08:17 PM
MySR71's Avatar
MySR71
Thanks. A friend of mine had some label transfers made. His looks a bit cleaner than mine.
Like I said, it will look as good as the effort you put in.
Old Feb 23, 2010 | 09:42 AM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
Why not just put it in the glove box.... I did
Old Feb 23, 2010 | 10:07 AM
0Double D Mods
Former Vendor
you know
I looked at your bezel many times and never even noticed that you didnt have the hvac there.
Thats a good idea. I ight have to make a note of this if and when i go with a carpc to get a larger screen
