Nitogen in tires
Personally, I dont use it in my personal cars. I dont like it. So some reason it makes the ride alot stiffer. Plus the temperature of the tires does not increase as high during hard use giving me less traction.
Plus Side? Lower chance of blow-outs. Regular air has around 85 % nitrogen anyways. There is only one machine that will pump 99.9% purity.
Later we bought a Mazda RX8, also equipped with the sensors. Had a similar issue with the air pressures. So, when I bought a new set of tires from the same guy, went ahead and put the nitro in them and again didn't have further issues with pressure sensors.
This past year we traded in the Jeep for a brand new Toyota 4Runner and the dealer we purchased from just happens to fill the tires, on every new vehicle they deliver, with nitrogen. I asked why and they told me the company decided to do it because of the increased number of vehicles being equipped with the monitoring systems and the number of customers that started coming back reporting them going off too often. Our 4Runner also has the TPMS and we have owned it going on a full year and have not had a tire sensor go off.
Many will call it "snake oil" and maybe it is. For me, the proof is in the results. I can't say I've seen any evidence of the other claimed benefits of running Nitrogen. I think any claim to increased mileage or longer tire life would only be because of the more constant tire pressures since poorly inflated tires can cause a decrease in gas mileage and/or premature tire wear. So, really the only claim I can't substantiate, based on experience, is a better ride. That too, could also just be based on more constant pressures.
At my tire shop, for the $39, it covers the life of the tires. So, if I get a flat or, for some reason have to add just plain old "air" to them, they will refill with Nitrogen at no additional charge.
Plus, you get the cool little green valve stem caps. LOL! And, for more blinged out cars, like my RX8 was, they might even throw in chromed caps with green tops on them.
FWIW, I am or have been a member of a forum like this for every vehicle I own or owned within the last 5 years, including a Harley. This topic has been posted on every one of them and they always have similar responses. Everything from true believers to those saying it's 100% BS.
So let's say the O2 molecules do leak out faster, every time you top the tire off the N2 concentration is higher than what you put in so at some point you end up with ~100% N2 (theoretically) If a frog jumps half the distance to the wall every time, theoretically he never reaches the wall.
Okay thats not what you said but may as well be.
The main difference to having nitrogen in your tires instead of "regular air" is the lack of moisture in nitrogen. This is precisely why aircraft and race cars use it because the moisture or humidity that comes out of a standard air compressor can catch and hold heat in your tires. When you are going 180-220 mph hot tires arent a good thing lol.
Now with that being said, there is 1 advantage a street car can benefit from using nitrogen over regular compressor air. Due to the lack of humidity in the tire with nitrogen you will not see nearly the fluctuation in tire pressure when going from a cold day to a hot day. Your tire pressure will remain much more stable. Worth the price they charge for nitrogen? Nope! Tire pressures are an item that should be inspected regularly. And you definitely should know when there's a pressure problem with our cars haha.
