[Z06] oil consumption?
Old Mar 9, 2002 | 06:52 AM
boxter's Avatar
boxter
Default oil consumption?
i understand the problems are associated w/ the rings. if you would replace pistons with performance "forged lower compression" piston/rings would that fix the problem completely. it seems like a pretty good deal could be found on a burner 01 z, with the money saved to lingerfelter.
Old Mar 9, 2002 | 07:55 AM
hcvone's Avatar
hcvone
Default Re: oil consumption? (boxter)
I have been looking for an 01' to put my 427 into, but they have not been giving them away. :(
Old Mar 9, 2002 | 11:54 AM
ZO6LS6's Avatar
ZO6LS6
boxter, sure it would.........are you putting a SC on one??.
If not, WHY are you lowering the compression ratio??......
Old Mar 9, 2002 | 12:08 PM
SWCDuke's Avatar
SWCDuke
Forged pistons will typically pass more oil because they have to be fit with more clearance than the OEM hypereutectic cast pistons. You don't really need new pistons, but whatever piston you run, the '02 ring package is the way to go.
Duke
Old Mar 9, 2002 | 01:15 PM
HummelS's Avatar
HummelS
Default Re: oil consumption? (hcvone)
Please define "giving them away..." :D
Old Mar 9, 2002 | 04:39 PM
boxter's Avatar
boxter
Default Re: oil consumption? (ZO6LS6)
zo6; actually i still don't have a vette yet, just wondering a good way to go. and the lingerfelter comment was reference to supercharging. :D
Old Mar 10, 2002 | 04:59 PM
ZO6LS6's Avatar
ZO6LS6
boxter, as Duke said, Forged will use more oil than cast.....for the reasons he described.
But, since you are considering a LPE SC, then by all means go forged, and around 8:5-1 on the CR.
They will do the job RIGHT the first time......unlike GM.
Good luck..............with LPE, you won't need it............I'll take skill & preparation over "Luck", anyday............... :D
To oil consumption?
