[Z06] Header install
Old Feb 26, 2010 | 11:51 AM
mdemers883's Avatar
mdemers883
Default Header install
Generally, how long does it take to install a set of headers on a c5z? I'm wondering how much it would roughly cost if I brought it to a shop to have them installed. What have you guys paid for your installs?
Thanks!
Old Feb 26, 2010 | 12:09 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Thanks!
We charge 450 for ARH Headers. 500 for other brands.
Old Feb 26, 2010 | 09:11 PM
heavymetals's Avatar
heavymetals
The gaskets will cost you around $30.00 and good hardware (ARP) another $100.00.
It takes an afternoon and maybe a little longer if you have lunch and dinner.
DUCK SOUP, but you do need to jack up the car.
Old Feb 27, 2010 | 01:56 AM
striper's Avatar
striper
Some jackstands and a jack plus a bunch of hand tools. I realize not every one can do this stuff but this isn't that difficult a job if you take your time and are careful. Plan a weekend if you've never done this stuff before. It took me a weekend to do my LG's but I had several things I wanted to do all at once, aside from the headers, too. You'll also have a bonding experience with your car and know more about it. There are some good threads here on the forum with pictures to guide you. I think Cajundude posted good instructions with pics. Good luck if you try it.
Old Feb 27, 2010 | 09:23 PM
Edmond's Avatar
Edmond
Where do you suggest to get the ARP bolts from?
Old Feb 27, 2010 | 09:31 PM
71corv's Avatar
71corv
St. Jude Donor '08
The hardest part of the install, for me, was the removal of the exhaust manifolds along with the plugs and getting everything loose without breaking anything. Once this was done the rest went just fine.
Gene
Old Feb 27, 2010 | 09:41 PM
Edmond's Avatar
Edmond
Since the plugs and wires have to be removed, I'm changing them out. I figure the extra money is well spent since the work has to be done anyway. I've got about 52k on the car and assume that it's the factory plugs and wires.
Old Feb 27, 2010 | 09:47 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
My bro and I installed LG long tubes on my car last month. It took a weekend; about 5 hours the first day and maybe 2 hours the second day. We did this on jackstands, no lift... wasn't TOO hard. As far as why it took as long as it did:
1) We had never done headers before;
2) We had fitment issues (some pipe ends were oblong and didn't want to sleeve over the next pipe properly... some time with a C-clamp massaged the problem ends back to round)
3) We spent a lot of time going back and forth between the car and a laptop with Cajundude's instructions.
4) Time included installing a new tunnel plate also.
All in all... it was a fun experience and I feel like I know my car just a bit better now! Just gotta be patient but it does go together.
Old Feb 27, 2010 | 10:09 PM
heavymetals
http://www.jegs.com/i/ARP/070/434-13...oductId=744890
Old Feb 28, 2010 | 09:53 AM
Edmond's Avatar
Edmond
$100 for a set of bolts...
Old Feb 28, 2010 | 10:18 AM
Paul 75 L82's Avatar
Paul 75 L82
I've used every type of header bolts and this is what I use now and will use in the future.
http://www.jegs.com/i/Percy%26%23039...21001/10002/-1
Old Feb 28, 2010 | 10:25 AM
Edmond's Avatar
Edmond
Those look like they work well.
I'll have to check out what other bolt applications they have.
Old Feb 28, 2010 | 12:00 PM
Vette C5's Avatar
Vette C5
Does anyone have the link to Cajundude's header install instructions?
I tried doing a search and no luck.
Old Feb 28, 2010 | 12:37 PM
81c3's Avatar
81c3
Here ya go!
http://www.cajundude.com/c5techhome.htm
Old Mar 1, 2010 | 01:39 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
about 1.5 hours w/ 2 people at the Carlisle event, we had 2 lifts last year
www.americanracingheaders.com
the stock header bolts will work fine, complete waste of money on anything else
if you have questions post or pm, I've done a few sets
Old Mar 1, 2010 | 02:56 PM
bullitt4110's Avatar
bullitt4110
Stock bolts and stock GM LS2 header gaskets
The time it takes also depends on the headers being installed, for example and set of 1-7/8" headers are much more of a PITA than standard 1-3/4", a set of the older Kooks takes a little more effort than there newer sets due to some of the bends, etc... Most of the newer stuff goes in pretty easy for the most part though.
Old Mar 4, 2010 | 09:01 AM
Z0Slow6's Avatar
Z0Slow6
Hey guys question on headers.. Some headers don't have o2 bungs correct? If i install headers on with no cats and use all o2 simulators, will i have any type of issues with the way the car will run? Also will my car throw any codes due to this? Thanks!
Edit: If i get a tune the outcome would be the same correct - if i plugged my car into the computer to get it inspected would it pass?
To Header install
Old Aug 6, 2012 | 08:31 PM
black.z51.c6's Avatar
black.z51.c6
Just a update, put on obx longtubes no cats, sounds amazing with the borla s type 2s. The sound is a lot differant and much more muscle car sounding. Put the headers on in my apartment parking lot, got the car 15 inches off the ground by using 6 2x12x16 under each tire. Fit was good no major issues with the install. Did take 8 hours with the help of a friend/coworker. We are both Toolmakers and mechanics, not used to working on cars but we build and repair machines daily so not that much of a stretch. THE ONE THING I WILL STRESS IS KEEP THE SLAVE CYLINDER HOSE FOR THE HYDRAULIC CLUTCH AWAY FROM THE HEADERS. I MELTED THE HOSE DRIVING THE NEXT DAY AND SPENT 1600 TO GET IT FIXED AT PAUL MASSE CHEVY. The mechanic told me had I moved the hose a 1/4 inch away from the header I would have been fine. Live and learn I guess. Name:  378.jpg
Old Aug 7, 2012 | 06:46 AM
SS2001SS's Avatar
SS2001SS
I'm having American Racing headers w/ x pipe installed and car dynotuned at Vengeance. Total out the door with tax and everything right at $3000. But figure they charge $590 for the tune, and the American system is $1800, so ~$600 for labor, supplies, and tax for the install by one of the best shops in the southeast.
Old Aug 7, 2012 | 08:08 AM
rnelson11's Avatar
rnelson11
Your car looks kinda like mine when is up except my 2"X12s are 24" long and I have about twice as many.
