I have a set of black outs on my rear and I have spray painted the screws black but I just dont like the screws showing. Doesnt make it very clean and smooth look. So is there a kit out there that has great fitment and only uses 3m tape?
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Yep there sure is. Im not sure who makes them but mine just use tape. There is a lip on the black out that goes in between the light and the bumper that also helps hold it on.
Reason: 23 and still can't spell
I had a set of the tinted covers shown in post #2. I used the proper prep before install and had one fall off a month later. Now I have louvered covers that get screwed on. I did not like the look of the screw heads either. I went to the hardware store and purchased some screw caps. You just put the screw through it, tighten the screw, then cover the screw with the cap. It is like a clam shell. They come in black, brown, and white for sure. I have also used these caps for the screws in the hatch area and the three screws in the doors (when open). It is a clean look for very little money!
That sucks man. It was a pain in the *** to get one of mine off. Once I put them on its like they lock between the light and the bumper. They are in there pretty tight.
