i own a 2002 c5 conv with a bose 12 cd changer mounted in one of the trunck compartments,i truly cannot drive over a nickle without it stuttering, never skipping a beat but stopping for a milisecond. has anyone ever had the same problem and if so whats the fix?
We have an 03 and I don't remember ever having a skip. I've actually been surprized how well the unit works. Wonder if something could be wrong with yours?
Bill
As great as the 12-disc CD player must have been 10ish years ago, I'm sure most are doing the ipod thing these days. I'm not one of them - yet. I use mine occasionally. Even with the Z51 suspension on my '99 coupe, have never had any skip or delay issues.
simple 5 minute install
unhook your changer
use the Ipod kit including the PXDP/PXHGM2 package to plug into the changer harness
run the cable to desired location in the front of the car
plug in ipod
you have tunes
I never had that problem with mine. Did away with the cd player anyway. Went with this.
"GM10-AUX". $60 or so. Unplugged the 12 disc cd changer in the trunk. Plugged this in, and got an RCA audio plug with the headphone jack at one end. All set to play any mp3 player. I got mine on that big auction site.
The factory 12 disc changer in my 2002 works perfectly. It's probably only skipped a dozen times in the 7000 miles I've driven the car.
If mine skipped frequently, I'd start by removing it from the car and taking it apart. It should have some sort of suspension system in it. Inspect that system and make sure it is insulating the player from shock as it should.
anyone know if an '03 Z06 is already wired for a cd changer back there? I would love to use this gm10-aux setup.
if ou have a changer yes
if not
more than likely no
if wanting to use for an ipod this will not charge
if want to use for a Zune or other 3.5 v option you will need the
pxdx/pxhgm2 option i have for the rear of the car
pxdx/pxgm4 option for the head unit
both of these will not charge zune or mp3 players
if you have an ipod or iphone you will need
pxdp/pxhgm2 for back of car
pxdp/pxhgm4 for from
both these options will charge ipods and iphones newest 5v systems.
could be that the lense is dirty (it's not really mounted in the worst place, but after time is could exposed to a bit of dirt and dust). i've never had to clean mine, but i do know there are ways to do it. just a guess on my part however.
