is this true?
Old Mar 6, 2010 | 11:23 AM
ssidekickbp's Avatar
ssidekickbp
Default is this true?
Someone told me that the metal valve stem covers are bad for the sensors? Is this true, anyone ever have any problems
Old Mar 6, 2010 | 11:31 AM
87SAM's Avatar
87SAM
I have heard that mentioned but I have had no problems with them.
Old Mar 6, 2010 | 11:38 AM
Rodster21's Avatar
Rodster21
I have the ones with the corvette emblem and never had any problems.
Old Mar 6, 2010 | 12:14 PM
zagger's Avatar
zagger
If the metal rim does not interfere with RF I don't think adding a cap would make a difference. Anyway my metal caps never been a problem.
Old Mar 6, 2010 | 12:20 PM
timmmmay's Avatar
timmmmay
I just installed the aluminum ones with C5 logos from Ecklers. I have noticed a y difference. I do think my left rear has a weak battery but that's not the aluminums fault.
Tim
Old Mar 6, 2010 | 12:37 PM
LoneStarFRC's Avatar
LoneStarFRC
No. It's not true.
Old Mar 6, 2010 | 12:57 PM
jrose7004's Avatar
jrose7004
I've had metal covers on both C5's that I've had and it hasn't caused any problem at all.
Old Mar 6, 2010 | 01:03 PM
R Devil's Avatar
R Devil
They've been on my 98 since new. No issues.
Old Mar 6, 2010 | 01:10 PM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
Iv heard the same.. something about them getting stuck on there... Who knows
Old Mar 6, 2010 | 03:51 PM
PETE O.'s Avatar
PETE O.
The valve stems are metal so why would it hurt?
Old Mar 6, 2010 | 03:57 PM
itzza427's Avatar
itzza427
No problem here either!!
Old Mar 6, 2010 | 03:59 PM
MG RED 99's Avatar
MG RED 99
I've never had a problem in ten years.
Old Mar 6, 2010 | 04:09 PM
Jistari's Avatar
Jistari
The transmitter and antena are in the epoxyed pack which rides inside the rim, the signal travels out through the tire towards the center of the car, not through the rim towards the outside world, so I would doubt anything you do outside the rim is gonna matter.
Old Mar 6, 2010 | 05:01 PM
RedSoxFan's Avatar
RedSoxFan
I never had a problem with mine, then when I had new tires put on the tire shop replaced them with ugly plastic ones. I called them and asked what happened to my metal caps and they said they always discard them and replace with plastic. Explanation was that they can corrode and cause problems. I've done business with them for years so didn't argue the point, just went out and bought some new ones with the C5 emblem and have not had a problem with those either.
Old Mar 6, 2010 | 05:13 PM
ssidekickbp
thanks for the input......the things some people say
I will get the metal ones then.
Old Mar 6, 2010 | 05:44 PM
JerG's Avatar
JerG
Not true. The original sensors on my 99 made by Schrader in CT, it came with with metal
caps marked as well.
One thing to watch is how the aftermarket valves fit with different aftermarket caps.
I did have a slow leak when an aftermarket cap bent the inner removable valve slightly.
Old Mar 6, 2010 | 06:13 PM
abigfoot's Avatar
abigfoot
Only if you drive with a tin foil hat on!
To is this true?
Old Mar 6, 2010 | 08:25 PM
onebighitter's Avatar
onebighitter
The reason the metal ones are bad is because they corrode to the sensor. Here in Wisconsin the road salt is what causes the corrosion. Since we do not drive them in this weather it is not a problem. Nissan is recalling vehicles right now that have sensor caps corroding to sensors and are putting on plastic ones. Two days after I purchased my vette I took off the metal ones and put plastic ones on, sensors are too expensive to me for a valve stem cap.
Old Mar 6, 2010 | 11:29 PM
LoneStarFRC
Incorrect. The metal valve stem, either partially or totally, serves as the antenna for the TPM.
Old Mar 6, 2010 | 11:34 PM
LoneStarFRC
Interesting. My '99, which I bought new, came with the "bullet shaped" gray plastic (nylon I think) caps, also marked with the "Schrader" name.
After my recent conversion to the newer, later style TPMS, the GM OEM sensors I received came with aluminum caps.
