Key FOB Question
Old Mar 10, 2010 | 04:09 PM
NYVette01's Avatar
NYVette01
Default Key FOB Question
Over the winter I had my battery out of the car. I just put a brand new battery in my key FOB and it won't work with the car.
How do you code these in to the vettes?
Old Mar 10, 2010 | 04:25 PM
feb2910's Avatar
feb2910
Cruising
procedure is in the owners manual
Old Mar 10, 2010 | 04:27 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If you hold down the lock and unlock buttons together standing near the driver's side of the car - hold them down until the horn honks, the fob will be "resynched" to the car. This generally happens anytime you disconnect the battery.
Old Mar 10, 2010 | 04:36 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
This is absoloutly true - I had to do this the other day when I swapped out my battery - it is a resynch and it does not mean anyone can use theirs if they came by and hold the buttons on theirs
Only ones that have been synched to the Vette before
Thanks,Matt
Old Mar 10, 2010 | 04:40 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Programming Transmitters
1. Turn the ignition to ON.
2. Turn the radio to OFF.
3. Press the RESET button in order to clear any IPC warning messages.
4. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
5. Press and hold the RESET button for 3 seconds.
6. Press the OPTIONS button until FOB TRAINING message is displayed.
7. Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
Old Mar 10, 2010 | 05:01 PM
NYVette01's Avatar
NYVette01
Worked perfectly. Thank you.
Old Mar 10, 2010 | 05:27 PM
Mark C5's Avatar
Mark C5
Glad I could help
To Key FOB Question
