New battery time
Your battery is located diretly over your computer. Although ruining the $165 computer is not the problem, its corroding all the connectors ! The problems and cost to replace these could be endless (I've seen quotes of $7500 to replace wiring harnesses)
I use an Optima Red Top, BUT I also use a battery tender on it when it sits 3 days or more. AGM batteries are not good for sitting and discharging, it WILL affect their life. C5's are battery hogs when sitting.
So, you now have a tremendous choice of good batteries. I have the AC Delco 7YR Professional battery. This battery will almost definitely last longer than 7 years. It has a 50 month free replacement warranty - best in the business. The Optima Redtop, like the 01-03 AC Delco AGM battery, can be reliable if kept well-charged. If not, it is more susceptible to early failure when compared to a good non-AGM like the AC Delco Professional.
But if you are like C5 owners who feel better running runflat tires, the best AGM out there is the Sears Platinum. It weighs almost as much as a boat anchor and costs $180, but to its credit, it is an excellent battery.
If you are on a limited budget, two batteries that come to mind have proven to be very reliable:
The Costco Kirkland battery and the
Walmart MAXX battery.
Either will give you 5+ years for less than $80.
http://forums.corvetteforum.com/c5-t...or-optima.html
http://forums.corvetteforum.com/c5-t...for-my-c5.html
http://forums.corvetteforum.com/c5-t...t-battery.html
http://forums.corvetteforum.com/c5-g...y-is-best.html
http://forums.corvetteforum.com/c5-t...h-battery.html
http://forums.corvetteforum.com/c5-g...-or-other.html
http://forums.corvetteforum.com/c5-t...-one-with.html
http://forums.corvetteforum.com/c5-g...-you-have.html
http://forums.corvetteforum.com/c5-g...esnt-leak.html
http://forums.corvetteforum.com/c5-g...t-battery.html
http://forums.corvetteforum.com/c5-g...your-hood.html
I found all of those in about 30 seconds. IMO, you are fine with any well known brand name battery. I run a DieHard right now b/c I happened to be going to Sears the day my old battery died. I have also had AC Delco Professional and Optima Red Top with absolutely no issues.
I have heard of individual incidents of battery problems recently, but not of one individual brand having more problems than most. I'm pretty sure I read somewhere that almost all car batteries are made by one of three companies anyway. Just buy something you've heard of that you can get a good price on. If your car sits for long periods in between driving buy a deep cycle battery like the optima yellow top so that it won't be damaged by the constant draining and recharging.
EDIT: Here is a link to a page on OPTIMA's site that is a pretty good overview of the different types of batteries... http://www.optimabattery.co.uk/engli...a/tutorial.htm
I've personally known too many people that have had all kinds of problems with them (sure there are some here who have not had problems).IMO, you should be able to leave a car sit for 3-4 days without having it sit on a float charger
That's just plain crap.Everstart is good, Diehard, AC Delco , I run the Excide Orbital. It's not cheap but I've had one now for 3 years no problem. I put it on a battery tender in the winter because the car sits from Nov-April without being started.
Stay away from Optimas
I have had my Red Top for 5 years and being a weekend driver I keep it on a float charger
