[Z06] Z06 Stereo Overhaul
Old Mar 15, 2010 | 10:41 PM
z06Maniac's Avatar
z06Maniac
Default Z06 Stereo Overhaul - Now with pics
This weekend I finally finished overhauling the stereo system in my Z06. WOW, what a difference!!! It's like having a house stereo in your car. I researched everything for months before ordering anything. The Audio section (and especially the Audio FAQ) of CF is the essential bible if you're planning on doing this yourself. I was selective in the components I chose to get both a powerful system as well as keeping the extra weight down, because it is still a sports car after all. It took me about 4 light weekends plus a few weeknights to complete.
I went with a Pioneer Premier head unit. It had everything I wanted:
  • 2 Aux inputs (I use one for my portable XM)
  • 2 USB inputs (bought a 16GB memory stick)
  • CD (with all the popular format support)
  • Integrated Bluetooth (not just BT ready)
  • Preamp outs (front, rear, sub)
  • 7 band equalizer
The speakers, sub and amps are all Alpine. The speakers and sub are all 'R' series. I went with a 6.5” component system for the doors, 5.25” speakers for the rear, and a 10" sub. The amps are F300/M500. I liked that the amps were matching form factor. For the rear speakers I had to fabricate some spacers out of ¾ plywood. This took a solid 2 hours to do. Without the spacers the speakers wouldn’t mount because the magnets on the Alpines were bigger than the Bose. I made a paper template, transferred it to the wood. I used a jigsaw to cut the holes, and a circular saw to cut outside lines. I’m glad I did the back speakers because they sound great.
I shopped the internet for all my audio components. I ended up getting smoking deals on everything. Most everything was at least 50% less than Crutchfield and MSRP.
I ordered most of my installation gear from MADVETTE. In general I'm happy with the quality of the gear. Dave’s customer support could be better though. Here's a list of what I got from MADVETTE along with my experience using it.
Insulation Kit. This is a very nice kit. I chose it because it is light (3.5 lbs) and it was advertised to cut noise by 19db. Excellent instructions and well thought out kit. Once you get past the jitters of gutting your interior, the kit goes in like butter. Everything is well labeled and the fit is great. The only thing that wasn't pre cut was the buckets in the rear of the car, but there was enough spare material left that I was able to fabricate that easily myself. The result: I can't believe how much quieter my car is, for a lightweight kit like this. I'm thrilled! If road noise is an issue for you, this is a no brainer upgrade.
Here's the interior stripped:
If you look closely at this one, in the center of the dash you can see the center support tab that must be removed:
Here's a pile of my interior :-)
Here's the insulation kit installed minus the door panels:
Stealth sub box. Nice box, blends well with the rest of the interior. Only weighs about 12 lbs (plus the sub of course) My only issue on the box was that I had told Dave the depth of my sub to verify it would fit, because my depth was more than the recommendation for the box. He never did verify it before he shipped it. I didn't quite understand that because all it would have taken was 30 seconds with a measuring tape. He did say he'd be willing to work with me if it didn't work out. When I installed the sub the magnet bent the spades on the box connector over because it's located directly below the sub. Good redesign would be to move the connector a few inches right or left. Dave said he would ship me a piece of wood to glue over the hole so I could relocate the connector, but he never followed through. I ended up soldering the wires to the spades and then shrink wrapped over them so I could fold them over flat. Problem solved. My type R sub sounds great in the stealth box, plenty of punch.
Amp Rack This is another very nice looking product. Dave talked me into going with the Plexiglas windows for the amps and a double wide fan. Maybe it’s just me, but I didn’t realize the amp rack is only the top cover? Fortunately, I had some scrap MDF lying around my garage and was able to fabricate an amp board. My email to Dave asking about the best location to mount the fan never got a reply. I initially screwed the fan to the underside of the amp rack, however, that resulted in an irritating whine from the motor noise telegraphing into the amp rack. The final solution, which worked really well, was to Velcro it to underside carpeted area of the amp rack. The result is the rack looks dynamite and the fan is now silent.
Amp board with distribution blocks and power wired:
With Amp Rack cover:
Head unit bezel The bezel looks very nice and was straight forward to install. The tough thing, at least for my install, was that I needed to trim off a big aluminum tab from the center support of the dash. The tab kept the head unit from going far enough into the dash to seat in the mounting sleeve. I used a hack saw to get the job done. Then I filed it smooth. The other thing I had to remove was a plastic cable holder on the upper right corner behind the head unit. Even with all that, the head unit was a tight fit. I cut the heck out of my hands on all the sharp edges in there!
MDF Door plates These were nice pieces and well worth the money. Perfect fit for my 6.5” Alpine component system.
Cabling and distribution blocks All Dave’s cables (audio, power, and distribution blocks) are premium stuff. No complaints there. I had discussed with Dave using a zero gauge wiring kit. He said it would route through the factory firewall grommet, but that my hands would get tired. After fighting with it for a couple of hours I decided to go for plan B. I bought a 4 gauge Fosgate kit from Best Buys, which routed easily. Considering the amps I used, less than 1000 watts, the 4 gauge wiring was more than adequate. Now, it’s my own fault for ordering the zero gauge. Total overkill as usual. But, I wish Dave had told me that. It would have saved me lots of aggravation. Dave never responded to my email asking if he could do anything on returning the zero gauge kit. Not even to say **** off. He had also sent me some 4 gauge cable but no crimp connectors to attach to my amps. I scoured Austin, but couldn’t find anything that would work. I ended up buying some Fosgate 8 gauge cable and matching crimp connectors that worked just fine. Net: for my system, 4 gauge main power and 8 gauge to each amp was plenty of capacity, and it was easy to install. Anyone looking for a nice zero gauge kit? I’ll make you a good deal.
Conclusions:
Thrilled with how everything turned out
Huge improvement over the factory system
Very happy with the quality of everyone’s products
Note: I easily spent at least another $100 on connectors and odds and ends. If you buy from Madvette do so well ahead (weeks, if not months) of when you plan to do your work.
Happy my car is back on the road!
Old Mar 15, 2010 | 11:13 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Why didn't you pick an Alpine Head Unit?
Old Mar 16, 2010 | 08:03 AM
Paul 75 L82's Avatar
Paul 75 L82
I'm also ready for my install. I've been hanging around the Audio forum as well and I really have got alot of off forum help from markcz. He's really helped me understand the wiring. I'm still waiting on the Z06 faceplate and the door speaker adapters, other than that I have everything. I'm really looking forward to Ipod and Bluetooth. Glad your install went well. It's always funny when someone states that you can do this type of job in "X" number of hours, it's refreshing to hear you say how long it took. I'm the same way, do it once and do it right and double check as you go. Did you retain RAP?
Old Mar 16, 2010 | 08:38 AM
z06Maniac's Avatar
z06Maniac
The Pioneer had everything I wanted, plus I liked the looks of it.
Old Mar 16, 2010 | 08:45 AM
z06Maniac's Avatar
z06Maniac
Yeah, it did take a long time. But like you say, I took my time and tried to do everything to the best of my ability. I'd work on it until I got too darn tired to keep going or until a particular thing seemed difficult. A fresh start the next time I got a shot to work on it always seemed to make things go easier. I must have made at least 7 or 8 trips to various hardware stores and electronic stores to get everything I needed. I also replaced all the factory speaker wire with 12 gauge speaker wire.
No, I didn't do RAP yet. I may do that in the future. RAP (Retained Accessory Power) requires an after market adapter, unless the head unit has built in GMRAP support. RAP Requires detection/decode of the digital serial port signal. The Peripheral Electronics adapter looks like the most low cost option at around $41. http://www.autotoys.com/x/product.php?productid=8503
I didn't figure out until I was close to wrapping up, and I wanted to start driving my car again.
Old Mar 16, 2010 | 10:27 AM
RussBt's Avatar
RussBt
I've always used the Alpine head units. I also used all top shelf Alpine amps in my last install (Jeep Grand Cherokee) and I was happy with them.
Old Mar 16, 2010 | 11:38 AM
tlove32's Avatar
tlove32
All of that reading....and you don't post pics?
Old Mar 16, 2010 | 01:34 PM
Its Bruce's Avatar
Its Bruce
Old Mar 16, 2010 | 02:00 PM
Pchild's Avatar
Pchild
Originally Posted by Its Bruce
Old Mar 16, 2010 | 07:02 PM
z06Maniac's Avatar
z06Maniac
OK... yes. I did take pics. Fighting with my wife's iPhone to get them sent to my email so I can post them.
Old Mar 16, 2010 | 09:45 PM
z06Maniac's Avatar
z06Maniac
I looked at the Alpine. Didn't see one I liked as much as the Pioneer or that had everything I wanted for the price I was willing to pay. I'm very happy with the Pioneer.
Old Mar 16, 2010 | 09:48 PM
z06Maniac's Avatar
z06Maniac
Originally Posted by Pchild
Finally got the pics off that pesky iPhone! Updated post at the top with pics.... Hope you enjoy
Old Mar 16, 2010 | 09:58 PM
Zidane's Avatar
Zidane
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Looks great and good post. I've been wanting to do this for awhile. Maybe this summer...
Old Mar 16, 2010 | 11:14 PM
RussBt's Avatar
RussBt
I used the PDX 1.1000 and PDX 4.150 in my Jeep install. Head unit was an Alpine IVA-D901 Screen. I don't want to add the weight to my Z06.
Old Mar 16, 2010 | 11:17 PM
95wht6spd's Avatar
95wht6spd
What insulation kit did you use?
Old Mar 16, 2010 | 11:29 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
I've never liked Alpine stuff, Pioneer Premier has always been good to me and had more features and better looks for the dollar than Alpine.
Old Mar 17, 2010 | 06:52 AM
z06Maniac's Avatar
z06Maniac
I used the Madvette kit
To Z06 Stereo Overhaul
Old Mar 17, 2010 | 07:10 AM
z06Maniac's Avatar
z06Maniac
I struggled with the notion of adding the weight too. The only things that added any significant weight are the sub/box assembly and the amp board/rack setup. I hooked up all of that with quick disconnect connectors. So, if wanted to, I could unplug all of it and go racing. The door component system is definitely lighter than the Bose setup, and the head unit is equal or lighter than the Bose as well.
If I was really worried about shedding some weight I could go on a diet
Old Mar 17, 2010 | 07:53 AM
Paul 75 L82
Pics look good
Old Mar 18, 2010 | 08:52 PM
z06Maniac's Avatar
z06Maniac
Pics look good
Thanks Paul. I still can't get over the night and day difference between the stock system and how it sounds now. Don't know how I lived with it before! I just bought a 16GB memory stick for $39. Fits every song in my MP3 library, with lots of room to spare. Amazing! The stock systems can't compare to all the features you get with a premium after market system.
