Hoe do I get the shift knob off???
Old Mar 20, 2010 | 09:05 PM
FYNL4's Avatar
FYNL4
Default Hoe do I get the shift **** off???
2002 6 Speed.
Old Mar 20, 2010 | 09:08 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Pry the center piece off with a small screw driver and you will see the top of the "Demon Key". It's called that for a reason, it can be very difficult to remove. Most have luck gripping it with a pair of vise grips and hitting the grips with a hammer until the key comes out. Then the **** pulls off. Gook luck
Old Mar 20, 2010 | 09:12 PM
slvrzo6's Avatar
slvrzo6
You've got it all right.... Except after you get the "Demon Key" out the **** SCREWS off, It does not pull off. But other wise, what he said..
Old Mar 20, 2010 | 09:22 PM
FYNL4's Avatar
FYNL4
Thanks guys, I appreciate the quick response...
Old Mar 20, 2010 | 09:52 PM
ALLEGRO's Avatar
ALLEGRO
The key can be a bugger sometimes. My favorite method is to use needle-nosed vicegrips, and then rap upward with a hammer. I will not take much force, but it may take several raps before the key comes up. Then, as mentioned, just twist off the ****.
Good Luck
Old Mar 20, 2010 | 10:10 PM
SSTG's Avatar
SSTG
Do all the aftermarket ones just screw on after that?
Old Mar 20, 2010 | 10:23 PM
Paulg680's Avatar
Paulg680
CI 7-8-9 & 12 Veteran
Wounded Warrior Escort '11
This is also a great time to cut up to an inch of additional threads and cut off an equal amount of the shifter lever using a hacksaw. It only takes about 15 minutes and significantly improves the look and feel of the shifter at minimal cost.
Old Mar 20, 2010 | 10:33 PM
ALLEGRO's Avatar
ALLEGRO
Been there, done that, and completely agree.
Old Mar 20, 2010 | 10:37 PM
Dave68's Avatar
Dave68
Yes - 9/16-18 threads. By the way, here's the way I remove the demon key:
http://www.conceptualpolymer.com/corvette_install.htm
Old Mar 21, 2010 | 02:43 AM
rickko's Avatar
rickko
There's always more than one way to skin a cat...
Poor man's way to lower your shift **** without need of hacksaw and the ensuing mess: You can drill out the center of the **** then enlarge the hole equal to the size of the threaded hole, then dremel out the stuff under the **** cap. Now you can screw the **** down much further than stock.
Old Mar 21, 2010 | 02:59 AM
Hammer99's Avatar
Hammer99
Good idea Rikko!
I had great luck removing the demon key with one of those paint can openers...the screwdriver with the curled up end. Pops it out in about 10 seconds!
Old Mar 21, 2010 | 03:13 AM
Jesse Asis's Avatar
Jesse Asis
As stated, pop the plastic 6 speed cover, vise grip on the wedge, slip a long screw driver in the body of the vise grip, hit the screw drive up with a hammer until the wedge pops off, kinda like s slide hammer, then un-screw counter clock wise... PS : Watch your face when doing this, one slip and you will be driving yourself to the hospital with a broken shifter and a missing tooth. I put in a black 2" 8ball shifter and cut off 3/4' off the thread top of the shift lever to shorten the shifter, love the feel. Enjoy the ride.
To Hoe do I get the shift knob off???
