is this a myth?
Old Mar 21, 2010 | 07:35 PM
ssidekickbp's Avatar
ssidekickbp
Default is this a myth?
Does using the seat entry wear out the electronics? I first had someone tell me this the other day and I don't buy it. anyone know?
Old Mar 21, 2010 | 07:51 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Of course it does.
Running the engine also wears it out.
You can park it and admire it or drive it and enjoy it.
If it bothers you then don't use the easy entry feature.
Old Mar 21, 2010 | 07:54 PM
Chicago1's Avatar
Chicago1
Anything that has some type of moving part will wear out eventually. So yes
Old Mar 21, 2010 | 07:57 PM
65GGvert's Avatar
65GGvert
If you don't use it, and it doesn't wear out, what good was it to have anyway. Use it till it wears out and then don't use it. I doubt you will get in and out enough to wear it out. If so, you'll have the choice to repair it or ignore it.
Old Mar 21, 2010 | 09:40 PM
Z06Electron's Avatar
Z06Electron
Yes and my 55k miles Denali Truck will tell you $800 for a new track and no motor replacement is !!! Oh and you can't ignore it cause it grinds like hell for a mintue or two every time you get in and out.
Old Mar 21, 2010 | 09:42 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I really don't think it will wear out the electronics, But the machanical parts yes.
Old Mar 21, 2010 | 09:44 PM
Z06Electron
My motor is what blew. Hell the electronics still run the broken motor to hell each and every time
Old Mar 21, 2010 | 09:58 PM
mcgilles's Avatar
mcgilles
in the C5 I think the problem comes from how the seat moves back but doesn't move up with the easy entry feature. because of the way the seat is designed (badly I might add) the mechanical components will rub against the carpet if the seat is moved all the way back while its in the lowest position. I ride with my seat as low as it can get, if you do the same your seat will drive the rear vertical adjuster arm into the carpet while moving all the way to the rear.
when I bought mine that rear adjuster arm, the plastic piece, was broken, and there is a rip in the carpet from where it wore through over the years. I turned the feature off. paid $550 to buy a new seat track, and programmed my #2 memory seat button for get out position, all the way back AND all the way up, so the seat doesn't dig into the carpet and cause damage to both. I have to manually hit the button when I get out of the car, but hey, it could be worse!
Old Mar 21, 2010 | 10:14 PM
lespaulr0cker's Avatar
lespaulr0cker
I think I'd try disconnecting the wires to the motor to rid myself of that.
Old Mar 21, 2010 | 10:23 PM
damilleniumboy's Avatar
damilleniumboy
that is what I did. It would **** me off when the seat would move when I would press the 1 or 2 buttons on the door. I'm the only one that drives it, so I could care less for the easy entry-exit BS.
Old Mar 21, 2010 | 10:49 PM
SCM_Crash's Avatar
SCM_Crash
You know you can turn the easy entry on and off through the DIC, right? LOL
Old Mar 21, 2010 | 11:12 PM
3BVert's Avatar
3BVert
I agree with 65GGvert. As to what your friend is talking about, I believe that the "Easy exit" feature accelerates the deterioration of the rubber isolators that cause the common, "rocking seat" issue on C5s. I just repaired my seats yesterday. Here is a picture of the old isolators. The ones on the left are from the driver’s side and until now, I’ve used the easy exit feature. Bottom line... both sides wore out but the driver's side was worse.
Old Mar 22, 2010 | 02:14 AM
Z06Electron
Doesn't much matter when my wife and I swap and each key fob has its own settings (only one of the three motors is out). Sure I can shut it off, but a $50,000 truck with 55k miles shouldn't have as many issues as my truck does. I only put up with Corvettes because no other Car manufacturer has any competition for them. GM has sold me my LAST car or truck. Corvettes will represent the only product they sell me again. My Acura was stupid reliable and aside from our VW I have never had so many issues with a vehicle in my life. The only reason my cluster works is because of the damn recall, or that would be broken too.
Old Mar 22, 2010 | 02:34 AM
DeeGee's Avatar
DeeGee
Default Thinking Laterally
Yes the moving parts will waer out but by far the biggest issue I see here is with sticking seat switches causing a drain on the battery
You could say that by using Easy Entry there's less risk of the switches breaking.
Old Mar 22, 2010 | 05:08 AM
Just makes sense that the more you use something, the more wear the parts will have.
Old Mar 22, 2010 | 05:15 AM
SCM_Crash's Avatar
SCM_Crash
That's exactly what my dad said to me. After buying the Solstice GXP, he said he'll never buy another GM ever again. The Solstice is a POS and the quality of every GM we've purchased in the past 10 years has been garbage.
*I*, however, loved my Corvette. I will continue to buy C5s until I see a reason to buy other which I don't see happening anytime soon. Driving my Z06 made me almost as happy as my GF has made me.
To is this a myth?
