[Z06] Vats key code?
Old Mar 22, 2010 | 09:23 PM
Bruce Wayne's Avatar
Bruce Wayne
Default Vats key code?
Need to have a spare key made for my 2003. How do I know what VATS code blank to order? Anybody know where to get one with the
50th anniv logo?
Old Mar 22, 2010 | 10:09 PM
Beau68's Avatar
Beau68
You can bring your key to the dealer and they can read it. There are 15 different types. Unless you find a descent dealer, they will charge you to read it. I bought my keys from Ecklers because they were a fraction of the cost of the dealer. The problem is getting it cut. I took it to the dealer and they wouldn't touch it even though it was a G.M. key still in the package. I took it to Lowe's home improvement and they cut it for me. It will only work one way though. Dealer told me they wouldn't cut it for that very reason. They have tried cutting their keys and had the same problem and didn't want to be responsible. I have an after market key which works both ways. Go figure. Well good luck key hunting.
Old Mar 22, 2010 | 10:31 PM
76 VETTE's Avatar
76 VETTE
I just went through this .I used my ohm meter to measure the resistance.Went to E-bay and ordered the VAT blank .The seller tells you the res.code.I am now waiting for the key.Then I have to take it to a lock smith to get it cut.Dealer wanted $30 .But I don't know if that was to cut it or just read res. and sell me a blank.$12.49 inc. ship.from e-bay .
Old Mar 23, 2010 | 02:57 PM
waddisme's Avatar
waddisme
Same here. Measure resistance with DMM, went to local key shop to order key, but for some odd reason, they happen to have one that someone had ordered and never picked up, so I took that and got it cut - $10 total. Ordered remote from ebay and programmed myself $29. I was in stealership last week and they had a sign up - $80 to order replacement if you did not have key plus $40 for cutting (?). $120 total - WOW!
Old Mar 23, 2010 | 05:22 PM
LCZ06's Avatar
LCZ06
OK, I was a little confused on how this works but I'm starting to understand. I found some replacement VATS key blank that fits the 1997 - 2004 Chevrolet Corvette on E-bay. Each VATS key has a resistor embedded within the key-blade, and each resistor has 1 of 15 possible values. So, I found information on how to read the resistance value of the key here http://www.keybitslockandkey.com/los...nstruction.htm.
Now, so I figure out which of the 15 possible resistor values it could be. Order the correct one from e-bay. Now, where do I take the key and have it, "cut" or copied?
Old Mar 23, 2010 | 07:44 PM
76 VETTE's Avatar
76 VETTE
Default key
I haven't gotten mine yet.I thought I would take it to a locksmith to get it cut.
Old Mar 24, 2010 | 08:04 PM
76 VETTE's Avatar
76 VETTE
Default key
Just got my blank key from keybits.Only took 2 days.Very fast.Tomorrow i am taking it to a locksmith to get it cut.Stay tuned.
Old Mar 24, 2010 | 08:23 PM
Bruce Wayne
Can you tell us more about how to read the resistance with an ohm meter, maybe a pic showing the meter reading? Thanks
Old Mar 24, 2010 | 09:47 PM
76 VETTE's Avatar
76 VETTE
Default key
I don't have a camera with me right now but I can tell you to take an ohm meter and touch 1 probe to 1 side of the pellet and the other probe to the other pellet .You should get a ohm reading on this.As an example,lets say my resistance was 523.If you look at the chart on keybits website it is a code 2.this is for the key I ordered.
Old Mar 25, 2010 | 11:03 AM
LCZ06's Avatar
LCZ06
http://www.keybitslockandkey.com/los...nstruction.htm check out this link
Old Mar 25, 2010 | 02:34 PM
76 VETTE's Avatar
76 VETTE
Just got my key back from locksmith.Both sides work great.Total $12.49 for key blank and $2.16 for cutting.Less than $15
Old Mar 27, 2010 | 08:49 PM
Greg_E's Avatar
Greg_E
Here's the resistance values, in case anyone needs them.
VATS #, Resistance in ohms
1 392
2 523
3 681
4 887
5 1.13k
6 1.47k
7 1.87k
8 2.37k
9 3.01k
10 3.74k
11 4.75k
12 6.04k
13 7.50k
14 9.53k
15 11.80k
Old Mar 27, 2010 | 11:58 PM
Bruce Wayne
1 392
2 523
3 681
4 887
5 1.13k
6 1.47k
7 1.87k
8 2.37k
9 3.01k
10 3.74k
11 4.75k
12 6.04k
13 7.50k
14 9.53k
15 11.80k
Thanks!
Old Mar 28, 2010 | 12:54 AM
TheDingo's Avatar
TheDingo
Surely Bruce Wayne could have figured that out himself. I smell an impostor!
Old Mar 26, 2012 | 09:25 PM
pewter026's Avatar
pewter026
is there a way to figure out your vats code with out the key ?? i bought my 02 cheap not running and came with a key with no resistor in it
To Vats key code?
