Big Problem..Please Help
Old Mar 23, 2010 | 04:32 PM
01rarevette's Avatar
01rarevette
Default Big Problem..Please Help
I recently carried something in the back of my C5 Coupe. I sctratched the inside black trunk lid panel and it looks terrible. Any suggestions an fixing it or what can be done..
Thanks everyone
Old Mar 23, 2010 | 04:48 PM
dougbfresh's Avatar
dougbfresh
Get a can of black paint, fill in the scrath with spot putty, lake the lid off and respray it.
How exactly is the a BIG problem?
Old Mar 23, 2010 | 04:54 PM
DeeGee's Avatar
DeeGee
DIY Trunk Lid Liner.
I'd been seeing the trunk lid liners on some of the members Vettes but being a good Yorkshireman, the $150 price tag seemed a bit steep. I had a bit of a DIY morning and made one up myself
Parts:
A sheet of pegboard - Home Depot $3
A roll of black car carpet from Walmart - $8
Spray Glue - Lowes $4
Fastners – Autozone $4
Tools:
Steel ruler
Staple gun and staples
Drill, sanding disk and cutting disk
Sanding block and sandpaper
Measuring tape
I made a template from some wrapping paper and transferred it to cardboard. I then used the template to cut the pegboard shaping the edges to make it fit the space using a rotary cutting disc. You should trim enough to give a small gap to allow for the thickness of the carpet. Glue the carpet to the pegboard leaving a 2" strip. Fold that over the edges and staple around the edge after priming with the spray on glue. You may wish to fix velcro to the V Channels on the inside of the trunk lid. This will not hold the weight and the studs are essential. It may hold the liner in place a little better but add to the cost.
Mark positions for the studs carefully. Drill holes through the liner into the V Frame. The stud pushes through and fits tightly into the frame behind. There are 2 studs at the top and 2 at the bottom.
Most Important: Be very careful not to press too hard and drill through the trunk lid
The finished item:
The logo was embroidered by my wife. You could buy the commercial GM logo but that would add to the cost.
An enhancement may be to fit some foam blocks at the lower outer corners. This would prevent some minor flexing.
Old Mar 23, 2010 | 05:03 PM
01rarevette
Thanks for the help from the people that weren't being smart about it
Old Mar 23, 2010 | 06:45 PM
jrose7004's Avatar
jrose7004
I didn't see a smart a$$ answer in the thread. You didn't do a very good job of explaining your problem!
Old Mar 23, 2010 | 06:58 PM
dobewillie's Avatar
dobewillie
Good luck with your fix
Old Mar 23, 2010 | 09:12 PM
01rarevette
how bout any covers like stainless steel? thanks
Old Mar 23, 2010 | 09:54 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Parts:
Tools:
Steel ruler
Measuring tape
The finished item:
WOW!!! Nice job
Old Mar 24, 2010 | 08:37 AM
I had some spots/scratches on the inside coupe hatch lid on my '00. I had a body shop match the paint and spray the area. Looked great when finished.
To Big Problem..Please Help
