Do I have the correct FOB?
Old Mar 23, 2010 | 05:51 PM
mechanix19's Avatar
mechanix19
Default Do I have the correct FOB?
OK after doing some reading on the forum, I think I need a new key FOB. It keeps losing connection with the car and I just replaced the battery. I have a 98. From what I've read, I can buy a new FOB for a 2000. This will work with my 98 but I will lose the passive lock/unlock, which is fine with me because I'm not a fan of it. So is there anything else I need to watch out for or can I just buy any new FOB made for a 2000? Is there a certain part number based on my receiver or anything like that? Also, any suggestions on the best price? Thanks for all responses.
Old Mar 23, 2010 | 06:17 PM
nkx1's Avatar
nkx1
I'm not sure about specifics for your FOB question, but I can tell you that I was able to purchase two FOBs from ebay for around $40 (I may have overpaid). I had no problem programming them for my 2004 via the DIC. I saw some exact replacements for your FOB on ebay- try searching these terms: 98 fob corvette
Old Mar 23, 2010 | 06:20 PM
CorvettePartsBob's Avatar
CorvettePartsBob
This is Bob at Fichtner Chevrolet, a long time supporting dealer here on the Forum.
There are several options on the fob and only your vin # or option codes can tell you which one you need. If you give us a call at 800-234-5284 and have your vin # available we will help you with your information.
I have heard some people say the newer ones will work, but according to GM they will not work as the operating frequency is completely different.
Old Mar 23, 2010 | 07:07 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Any FOB for a '97-'00 Corvette will work. The FOB's for the '01-'04's will not work unless you change your receiver, which will mean you also have to change your tire pressure sensors.
Old Mar 26, 2010 | 11:36 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Feel free to contact me and I would be happy to help you out with your GM Parts needs.
Old Mar 27, 2010 | 03:35 AM
HD_2_C5's Avatar
HD_2_C5
I paid $19 for mine. The guy had to send me a few before I finally got one that the car would recognize but he didn't charge me a cent more. PM me if you want his contact info.
Old Mar 27, 2010 | 06:47 AM
65GGvert's Avatar
65GGvert
Not for his 98. You guys bragging about paying $20 used bought for the 01-04 and they won't work on a pre 01 car.
To Mechanix, order a new 2000 fob from Gene Culley at gmpartshouse.com. You'll get a new fob. You don't need a vin #, all 2000's are the same. You are correct in your original post, you won't have passive available. If you want that, Gene also has the 98-99 fob. It is a few dollars more. Don't make the mistake of ordering a used fob and end up with the same problem you have now.
Old Mar 27, 2010 | 06:57 AM
65GGvert's Avatar
65GGvert
You got all the answers in the thread below, you should pretty well have figured out by now which fob you need.
http://forums.corvetteforum.com/c5-g...ood-price.html
To Do I have the correct FOB?
