Tint Problem
Old Mar 25, 2010 | 05:45 PM
Mickman's Avatar
Mickman
Default Tint Problem
I'm getting my Z06 tinted, and the guys at the shop said they were having problem with the "Dot Matrix" in the back window, and if it is still bad in a couple days to take it back to them.
Does anyone here have any experience with this?
If so:
What can be done if the shop can't repair it or what can they do to fix it or get it done right??
Old Mar 25, 2010 | 05:49 PM
Gitusum's Avatar
Gitusum
its hard to get the tint to seal really well around those dots. my coupe has the same problem and i believe there isnt a fix for it but if there is i am willing to try it.
Old Mar 25, 2010 | 05:56 PM
jwil's Avatar
jwil
Could you use a heat gun in the area around the dots? I'm interested in knowing before I get mine done in a few weeks.
Old Mar 25, 2010 | 05:58 PM
Gitusum's Avatar
Gitusum
a heat gun was used around my rear window but it still isnt completely tight around the dots. the dots are so close together its tough to get a seal and it agrivates installers
Old Mar 25, 2010 | 06:11 PM
Bill Vett's Avatar
Bill Vett
I remember seeing that they sanded the dots down so the tint was able to lay flat. I'll see if I can find the thread.
EDIT: I couldn't find the thread but if you do a search "rear window tint " there are pages of info.
Old Mar 25, 2010 | 06:35 PM
Mickman's Avatar
Mickman
Thanks for all the responses guys! Sounds like this is a common problem when tinting
Old Mar 25, 2010 | 06:40 PM
dcd58's Avatar
dcd58
I've seen installers "spray tint" that section of window, then apply the film. I didn't do that so I don't know how noticable the 'line' will be
Old Mar 25, 2010 | 09:57 PM
abigfoot's Avatar
abigfoot
If so:
This has been a problem for years. My FRC was tinted 6 years ago and is still ok. You need a guy that has done it before.
Old Mar 25, 2010 | 09:59 PM
slvrzo6's Avatar
slvrzo6
My window tinter used a piece if Black Vinyl to cover the Dots at the top of the Rear window. It looks great and you cannot tell that it's not tint.
Old Mar 25, 2010 | 10:00 PM
jrose7004's Avatar
jrose7004
It's the nature of the beast. I've never seen a tint job that looks good around the dots!
Old Mar 25, 2010 | 10:05 PM
slvrzo6's Avatar
slvrzo6
Some Quick Pictures of my Rear window with the Vinyl at the Top covering the Dots.
Old Mar 25, 2010 | 10:19 PM
Slider-01's Avatar
Slider-01
I just had my coupe rear window tinted by a guy that had done many vettes and was familiar with the dot pattern. He said some stick and some don't; the ones that don't he uses the spray tint but some folks get real uncomfortable when he has to spray their Vette. Mine so far is sticking to the dot pattern.
Old Mar 26, 2010 | 05:01 AM
I've heard of installers using either of these two methods, as well as just working patiently to get the tint to look good around those dots. An experienced installer should be able to make it look very good, but it does take a lot of practice.
To Tint Problem
