Help with a flat tire issue
Old Mar 26, 2010 | 08:49 PM
sandhc5's Avatar
sandhc5
2nd Gear
Default Help with a flat tire issue
I got up and decided to take the ole vette for a spin. when I started it up a message came across the dic saying that i had a right rear flat. I put some air in the tire and turned the car off to reset the sensor. After checking the air in the tire manually i turned the car back on and it still read that there was 0 pounds of pressure in the tire. The manual gauge read 32 pounds.. Anyone else had this problem and if so how did you fix it. Thanks
Old Mar 26, 2010 | 08:50 PM
RedSoxFan's Avatar
RedSoxFan
The pressure won't show on the DIC until you've driven it a mile or two.
Old Mar 26, 2010 | 09:17 PM
Toms02C5's Avatar
Toms02C5
If that doesn't work (which it didn't on my car), you'll have to reset the TPM's (there are several threads on this).
Old Mar 26, 2010 | 10:32 PM
Aerovette's Avatar
Aerovette
Foolishly, I learned this when I tried putting air in my wife's Tahoe and kept checking the display only to find it was not changing...then I learned... it's not that smart, and I guess I wasn't either.
Old Mar 26, 2010 | 10:40 PM
sandhc5's Avatar
sandhc5
2nd Gear
Default flat tire
Thanks for the help guys. Im going to try to reset the sensors in the morning. Hope it works.
Old Mar 26, 2010 | 11:32 PM
jrose7004's Avatar
jrose7004
I had to put air in my right front tire today and it took about 9 miles of my 12 mile commute for it to read right.
Old Mar 26, 2010 | 11:44 PM
Hammer99's Avatar
Hammer99
It definately takes longer than you would think!
Old Mar 27, 2010 | 12:14 AM
damilleniumboy's Avatar
damilleniumboy
Yup same here. The car started flassing "flat tire, blah blah blah," so I stopped and looked, and my pressure was ok. It takes a couple of miles for the computer to recornize that the tires are up to par.
Old Mar 27, 2010 | 03:03 AM
Jistari's Avatar
Jistari
Dont sweat it, if you read the pressure and its proper with a hand guage, just use it, ignore the DIC for a bit (I wouldnt relearn the TPMS yet), see what happens.
To Help with a flat tire issue
