Replacing rear studs with ARP
Old Mar 28, 2010 | 02:00 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Default Replacing rear studs with ARP
Does anyone have a DIY with pics to replace the rear wheel studs? I'm upgrading to ARP's. How long does it take per side?
P.S.
I've searched on the board and couldn't find anything with pics.
Cheers.
Old Mar 28, 2010 | 02:24 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Search wheel hub assembly, i just replaced mine yesterday and you have to pull the hubs off the car to press out the bolts and press in the new ones.
Took me a 1.5 hr each side not a bad job just time consuming!
You also need a 34mm cv axle nut and a good breaker bar!
Mario
