Car buying question.
But if you have been on the forum long enough you will see some. An you wonder, is it easier to just ask questions because the computer sits in front of you. Or should you take the time to seek out the answer before posting.
Or do a search on the subject......Now there are three avenues you can go to, to determine you potential vehicles past.
1) ask the current owner
2) Do a CARFAX!!!!!!!!
3) Get the vin# (please don't ask where that is) and ask your local Chevy dealer is they can do a history check. Will also need the Vin# for #2......................................
4) None of the above will work, if--------------------
A) The owner lies to you.
B) An accident, if any was never reported......................
5) So if you are a person who gets in a car and just turns the key and drives, then as the last resort, because you really want this car, is to pay a CERTIFIED mechanic to go with you and check the car out.....
On the right side framerail and front bar, GM put the vin # in white. If the car was ever hit, it would distort the numbers. Obviously, if you find an incorrect vin # or if it's missing, then the car's been hit and it's probably time to walk away from the car.
To clairify, on all C5, the vin # is on the front right framerail. On early C5, 97-02, it's also on front bar as well.
Jerry
I guess I shouldn't have taken it for granted that everyone knows about carfax. I was wondering if there are ways to tell by looking at it, or a way that would be FREE. Sorry for the confusion. Thanks.
Also, if a car has been in an accident how much less should I pay off the asking price in a %? I am planning on a z that ranges from 40-50? If it has been in a small accident, or just a small fender bender, or maybe just hit in the parking lot, how much less is it worth?
Then when you have settled on a particular car that you want, this is the time that you have a friend who is a mechanic look over the car, take it to a dealer and pay them look over it and get a history report, get a Carfax or pay an out side professional to look over the car. If this is done right then either you will buy that car or dismiss it as a has been. You should only have to repeat this process once or twice if done right. Or perhaps after viewing candidates you might get an all knowing forum member to look at the vehicle with you.
And don't pass up your favorite Carmax.
If you had posted the important information in the beginning, then you wouldn't have gotten some of the "old wise man answer's ".
My last note, is that you stated that you were looking to buy another Vette. So in this instance you should be familiar in what to look for.........HMMMMMMMM?????
Also, I don't mind buying a wrecked car as long as it is properly fixed, but what % less should I pay off the standard price? Considering it is a small wreck, how much less should I expect to pay?
Just a couple of things you can check yourself.
