How do you put jack stands under a C5
- Place jack with puck at the right side forward puck location and jack the car as high as the jack will go.
- Place jackstands under the right side of the front and rear crossmembers.
- Release the jack and allow the car to come to rest gently on the stands.
- Move the jack over to the left side forward puck location and jack the car up until it is just past level.
- Place jackstands under the left side of the front and rear crossmembers.
The car should now be level on all 4 stands.
Some people say it's wrong to place the stand directly on the crossmember. They use wood in between. I dont trust that with my life. It complicates things and can make the process dangerous. I've never had a problem placing the stands on the outsides of the crossmsmbers. I do make sure I get the stands away from the center of the crossmembers as much as possible.
Never lift the car from the center of a crossmember.
place jack under center of front cradle
lift slightly, but do not lift wheels off the ground
loosen lug nuts slightly, but do not remove on both front wheels
jack up front of car
place jack stands under each side of the front cradle
remove front wheels
low jack
move jack to back of car
place jack under center of rear cradle
jack slightly, do not get wheels off the ground
loose rear wheel lug nuts slightly, but do not remove
jack rear of car up
place jack stands under each side of cradle
remove rear wheels
repeat jacking front and rear, to raise or lower on jack stands
HERE'S SOME HIGHLIGHTS FROM THE GM MANUAL:
The GM Manual states or implies:
1. ‘Jack Stands’ should NOT be placed under the ‘frame rails’ (regardless of whether ‘hockey pucks’ are used or not).
2. A ‘hydraulic jack’ should NOT be placed directly under the CENTER of the ‘OPTIONAL’ front cross-member. The ‘Optional’ Front cross-member is FORWARD of the front fiberglass transverse spring and is the ‘optional’ front location for a ‘hydraulic jack’. By contrast, the ‘PREFERRED’ front location is to the REAR of the fiberglass transverse spring, immediately forward of the oil pan. This 'PREFERRED' cross-member can have a 'hydraulic Jack' placed directly under the center, however, doing so will most likely contact and may damage the oil pan/oil drain plug, so it is NOT advisable either.
3. A ‘hydraulic jack’ should NOT be placed directly under the CENTER of the rear cross-member to raise the rear of the car.
AND SOME MORE HIGHLIGHTS FROM THE GM MANUAL:
......‘Vehicle Jacking’ (‘Hydraulic Jack’, not to be confused with ‘Jack Stands’ or a ‘service lift’) implies the use of ‘hockey pucks’ front and rear by specifying the use of “2 ½ inch or smaller diameter lifting pads when ‘jacking’ the car via the ‘frame rails’........
.....For the FRONT, this ‘Vehicle Jacking’ section continues to specify the ‘Preferred’ Front Suspension cross-member as the one behind the fiberglass transverse spring, immediately forward of the oil pan. This cross-member can be lifted anywhere along its width (center to 13” off-center), with the preferred location at the outer 7 ½ inches (and in the middle of that outer 7 ½ inches).
.......For the REAR, Similarly specified is that a ‘hydraulic Jack’ should NOT be placed in the center, it should only be placed at the outer and rearward sweeping 5 ½ inches (of the overall 26 inch length cross-member)........
........further specifies that ‘Jack Stands’ should only be placed under the outer areas of the three previously mentioned cross-members. Also, a ‘block or pad’ should be placed between the jack stands and the vehicle. Lastly, make sure the ‘jack stands’ ‘block or pad’ span at least 2 cross-member ribs (i.e. side to side thin aluminum ridge).
IMORTANT !! The pictures below are not implying you 'LIFT' the car with the center 2x6 balanced on a floor jack. YOU NEED TO screw/nail the small pads onto the large pad.
I recommend 2 floor jacks, bring up both sides semi-evenly until you can place the jack stands/pads. The reason small pads are on the long board is to keep the 2 jack stands from lateral movement (side to side) while keeping weight off the center of the Aluminum Cradle.
Here's the link to the work that 'theadmiral94' did
http://forums.corvetteforum.com/c5-g...ting-pads.html
Each winter I check to assure my frame is square, and it is.
If it's been a real issue, I'll have to re-think my method. Otherwise I feel safer without the wood. Placing the crossmember directly on the jackstand is far more sturdy IMO.
I can understand why we should not jack from the center of a crossmember. And I can understand why we should not attempt to place jackstands at the 4 puck locations, but until I see evidence of a crossmember damaged by a jackstand I just cannot understand why it is said to not place a stand directly on the crossmember ends (NOT in the center of the crossmember of course). Direct contact is always more stable and our cars are only 3,200lbs. That is 800 Lbs / jackstand. The aluminum ribs of the crossmember are thick enough to not fold over under that load, IMO.
.....The THIRD SECTION ‘Supporting the Vehicle with Jack Stands’ first notes “Important: Do not place jack stands under the frame rails”.[/COLOR]
It further specifies that ‘Jack Stands’ should only be placed under the outer areas of the three previously mentioned cross-members. Also, a ‘block or pad’ should be placed between the jack stands and the vehicle. Lastly, make sure the ‘jack stands’ ‘block or pad’ span at least 2 cross-member ribs (i.e. side to side thin aluminum ridge).
But, if you're going to go buy into one part of the what the engineers detailed, why not all of it?
To Anyone reading this thread:
I asked for this to be sticked because I think New Members should be able to find this information quickly, and from the Engineers that designed the GM Manual.
For those that want to 'believe' something else, that is your perogative, but I don't think 'less than' practices should be passed on.
I build Commercial Buildings for a living. I have a Structural Engineer that tells me how to build. When it comes to that same Structural Design, the Engineers at GM are the only ones that can tell us what the car and it's parts were designed to do when it comes to lifting.
Ever seen a 160' long roof truss in a 100,000 sq.ft. warehouse? It's made of 2x4s , the same you can buy at Home Depot, gang nailed together. Built in a system, they can hold tons of snow. But as an individual board, not much.
Same with the Metal ribs in the Cradles. Each piece is designed as part of a system and the ENTIRE SYSTEM is designed to hold the weight. Not just one of it's parts.
I say, better safe than sorry.....
As far as the jack stands... someone needs to engineer a bracket for using between the crossmember and the jack stands.. one that will kind of V up or U up over the crossmember and at the jack stand side, have a couple cutout or indentation areas where the jack stand ends will firmly sit in and not allow any movement or slippage. If any engineers or vendors are listening, this would be a good money maker for you. Same for if you engineer a bracket for jacking to distribute the weight on the crossmember with a small indentation where the jack would sit and not allow for slippage as you jack the vehicle.
The concept is to not put weight on the center, that's why you can't double up the boards when you jack it up (at least for the rear). GM states you can lift on the front in 2 places. One is in front of the leaf spring, and that area they state do NOT raise in the center. The other one behind the leaf spring you can lift anywhere, but it's not easy to get to from the front anyway.
I think someone posted a metal system that sells for around $45 sold at Summit racing.
Is the crossmember somehow not as strong in the middle? I don't believe that. I believe GM stated that so you don't put a small round jacking puck in the middle due to balance issues. I bet if you use a board across the whole thing and distribute the weight that you'll be absolutely fine. That keeps the vehicle balance and the weight distributed.
If you put one solid board across the entire cradle and place a floor jack in the center, then you are still putting all the lifting weight on the center as you bring the car up.
GM recommends lifting only on the outer 6" of the cradles. You are to either place the jack on the outer 6" and lift (which would be impossible to place jack stands and usually the front end is too low to get a floor jack in there unless you start with some small wood ramps).
It's really simple to do this lift with 2 jacks. You only need one 'low profile' jack, even if your car is lowered (mine is). Once you lift one side, the other side comes up quite a bit, allowing my 30 year old 6" high floor jack to clear and then I lift both sides. Place the block system (don't forget to screw small blocks to full length board) on the stands, slide it in, drop the jacks and your done.
Lots of good reading here in 'theadmiral94's original thread
