Quick Car Show Question?
Old Mar 30, 2010 | 12:36 PM
CG77VETTE's Avatar
CG77VETTE
Default Quick Car Show Question?
What's the best way to turn all the power off on my '01 Z so open hood / doors / trunk don't drain the battery? Is there a built in timer that already does this or do the lights stay on forever? Thanks for any help and tips on what I can do. Show season in the Norteast is quickly approaching and i want to be as ready as possible Have a Great Week
Old Mar 30, 2010 | 12:52 PM
memphis_vette's Avatar
memphis_vette
im pretty sure there is a timer that after 10 mins all lights go off
Old Mar 30, 2010 | 12:55 PM
Bill Vett's Avatar
Bill Vett
It might be closer to 15 min, but if you open the trunk/ hatch, doors, or hood it will start over... so get what ever you need out and don't open and close anything....
Chicago1's Avatar
Chicago1
I thought it was 15 minutes? But 10-15 minutes for sure though
Old Mar 30, 2010 | 01:05 PM
4SFED Z's Avatar
4SFED Z
disconnect the battery, lol. seriously, give it 10 min
Old Mar 30, 2010 | 01:10 PM
CG77VETTE's Avatar
CG77VETTE
Thanks for the reply. I'm aware of the timer when all is shut. I'm asking what happens if you leave the hood and trunk open, do the lights stay on indefinately or is there another timer? If no other timer, I may have to buy a battery kill switch.
Old Mar 30, 2010 | 01:11 PM
jrose7004's Avatar
jrose7004
They do!
Old Mar 30, 2010 | 01:24 PM
Chicago1's Avatar
Chicago1
There is one even if left open I believe it's 15mins
Old Mar 30, 2010 | 01:25 PM
68ragtop69's Avatar
68ragtop69
MD Events Coordinator
2015 C3 of Year Finalist
Cruise-In X Veteran
CI-X Car Show Winner
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
TI'm asking what happens if you leave the hood and trunk open, do the lights stay on indefinately or is there another timer? If no other timer, I may have to buy a battery kill switch.
The lights will shut off after 10-15 minutes (I never actually timed it) with the hood & trunk open; however, the timer will start all over if you open the doors after the lights shut off.
Old Mar 30, 2010 | 01:51 PM
Zr-1Mike00's Avatar
Zr-1Mike00
You can always unscrew the light under the hood... Thats what I have done....
Old Mar 30, 2010 | 03:20 PM
CG77VETTE's Avatar
CG77VETTE
That's what I used to do on my '86, simply unpluged the leads to the underhood lights. I'm just not sure how many other lights go on when the hood is opened. If I unscrew the hood lamp, do the other lamps stay on and for how long. I guess I'll have to use the trial and error method until I figure it out. thanks for you reply.
Old Mar 30, 2010 | 03:22 PM
Your car has a timer built into the courtesy and other lights to where after 15 minutes they will automatically shut off when the car is not running. Works very well to keep the battery from being discharged.
Old Mar 30, 2010 | 03:49 PM
Bill Vett's Avatar
Bill Vett
Just try this at home, open hood and doors and hatch. Have a beer and clean two wheels...Look up and you'll see that ALL the lights are now off. Now close the hood, open the hood..... have an other beer clean the remaining two wheels look up again....Lights out. I didn't want you to waist time just sitting there staring at your watch, Oh your wheels look great
Old Mar 30, 2010 | 04:33 PM
paint-tech's Avatar
paint-tech
I open all all mine up they will shut off and will not hurt you battery charge at all.
Old Mar 30, 2010 | 04:44 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
The lights will go out because of the timer however, if you open the door, trunk after the lights go off it starts all over again. I disconnect the hood lite for shows. You can find the connection on the passengers side under the headlight bucket or there abouts...
Old Mar 30, 2010 | 05:07 PM
Alaskanpilot's Avatar
Alaskanpilot
As far as the underhood light goes, I just unclip the wire that runs to it. It's located near the right side headlight, down by the radiator shroud. Blue clip, very easy to unsnap.
Old Mar 31, 2010 | 10:01 AM
68ragtop69's Avatar
68ragtop69
Cruise-In X Veteran
That is the same way I clean my wheels!!!
To Quick Car Show Question?
Old Mar 31, 2010 | 10:51 AM
TomBoy's Avatar
TomBoy
I show all the time. Timers will shut all hood, trunk, door, and interior lights down after 10 minutes or so. If you open anything, it will start over. I do it all day at the car show. Never a problem though. My husband made me these door props we painted MSG for shows. It will actually shut the door lights off because a screw hits the right spot to make it think it is shut. Oh, I like the beer idea on cleaning. Although, at the shows, can't have it. Bummer. Makes losing easier on you...
Laurie
Old Mar 31, 2010 | 11:28 AM
nkx1's Avatar
nkx1
In addition to the above suggestions of just letting the time shut off the lights, you could also replace the existing interior lights with LED lights that draw a fraction of the power of the regular lights. Even if LED lights were left on all day, it probably would not be much of an issue.
Old Mar 31, 2010 | 11:34 AM
tony car4a's Avatar
tony car4a
An alternative is to remove the bulb. I keep the bulb out all the time anyway.
