Idler or belt?
Old Apr 6, 2010 | 11:57 PM
thematrix17's Avatar
thematrix17
Default Idler or belt?
When I start my 2000 frc, I hear a belt squeal till the engine warms up 15 to 20 minutes later..could this be the belt or is an idler seizing up? ....thanks
Old Apr 7, 2010 | 12:05 AM
dare8601's Avatar
dare8601
I had the same or similar problem with belt chirp at idle...replaced belts and all better now...
Old Apr 7, 2010 | 12:11 AM
thematrix17
I am hoping it is just the belt as well...my friend seem to think it is going to be the idler...thanx for the input dare8601
Old Apr 7, 2010 | 01:21 AM
209TIME!!!'s Avatar
209TIME!!!
i had the same problem, i changed the belts and all the noise went away.
Old Apr 7, 2010 | 01:56 AM
corvettedaddy11's Avatar
corvettedaddy11
I changed to a gatorback belt no noise!!!!!!!!!!!!!
Old Apr 7, 2010 | 04:16 AM
thematrix17
Thanx I will try a gator back belt..
Old Apr 7, 2010 | 10:36 AM
postwhore's Avatar
postwhore
I had to change pulleys
Old Apr 7, 2010 | 10:59 AM
BCH & VET's Avatar
BCH & VET
did mine last month. thought it was going to be the idler on the ac belt, but wasn't...
if it turns out to be the idler pulley, you would want to get both new gatorback belts on there anyway...
Old Apr 7, 2010 | 12:48 PM
bucwheat's Avatar
bucwheat
It may be the tensioner also
Old Apr 7, 2010 | 12:51 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
changed the belt....it stopped then it came back changed the pulley and it stopped so far so good
Old Apr 8, 2010 | 07:17 AM
thematrix17
I am getting a new belt today...we will see how that works..
Old Apr 8, 2010 | 07:20 AM
BCH & VET's Avatar
BCH & VET
don't forget you'll need two belts
Old Apr 8, 2010 | 12:02 PM
lucky99's Avatar
lucky99
Take one belt off start it up makes it a little easier to find.
Old Apr 8, 2010 | 12:55 PM
Stealth_Inc's Avatar
Stealth_Inc
Mine always had a squeak in cold weather mornings. But it would always go away after about 10 minutes of driving.
Well about two weeks ago, it wouldn't go away. Took off the main accessory belt. Still there. Took off the AC belt. Gone. I then ordered a new tensioner, idler, and belt and installed it the same week (special order from Autozone). All is well, not a squeak since then, even though it was cold this morning
Old Apr 8, 2010 | 01:06 PM
wcsinx's Avatar
wcsinx
Exact same thing happened to me.
My idler pulley had visibly slung out all its grease. Got a new one at Advance for $20.
Old Apr 8, 2010 | 06:11 PM
paullywalnuts's Avatar
paullywalnuts
It could be anything thats visibly moving down there...pulley's,tensioners, belts...it has to be isolated to figure out what nees replacing..a trained eye can spot it.
Old Apr 8, 2010 | 06:49 PM
KeyoRacing's Avatar
KeyoRacing
Same deal I had a few years ago...drove me nuts. Goodyear Gatorback belts fixed it all.
Old Apr 9, 2010 | 04:53 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
i did gators, hit the track and they didnt do so hot. I went back to OEM. the gators tend to be a bit short on the main belt and dont like to go on. When you are there look at the idler and if it looks questionable just change it. Katech is the way to go to replace it, OEM stinks.
Old Apr 9, 2010 | 05:54 PM
2EZ 2SPD's Avatar
2EZ 2SPD
Same here, but I will add about 4 mo. later it through the belt off so now I replaced the Idler Tensioner now its OK.
To Idler or belt?
