Ms3 dyno numbers
Old Apr 7, 2010 | 10:18 PM
Nate B's Avatar
Nate B
Default Ms3 dyno numbers
I have an 02 z06 with a tsp ms3 cam, 1 3/4 long tubes, cats, stock catback, vararam and a ported t-body. It made 424hp and 377ft/lbs sae corrected with the intake pressure dropping 3kpa over 5k rpm. My tuner said the stock air bride would cause the pressure drop and would pick up close to 10hp with a better flowing one. The best track numbers I could get was 12.0 at 121mph with 2.1 60ft on street tires, and im not the best driver...
I now have a vararam bridge, no cats and b&b catback. I am also going to be installing some PRC stage 1 ported and polished heads here in the next few weeks. Any thoughts on power numbers or does anyone have a similar setup?
Old Apr 8, 2010 | 12:02 AM
marvinseah's Avatar
marvinseah
04 z06 with ms3, lg pros, halltech stinger intake, stock ti, asp pulley, and tune made 440/399.
Old Apr 8, 2010 | 12:15 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
01 Coupe MS3, LT's, CAI, ported TB, stock LS6 manifold and 241 heads made 413RWHP 387RWTQ. Just added a FAST 92 and LS2 TB new numbers coming soon.
Old Apr 8, 2010 | 03:58 AM
FourG63 97GST's Avatar
FourG63 97GST
your mph sounds about right, especially for having cats
Old Apr 8, 2010 | 02:55 PM
Nate B's Avatar
Nate B
Any idea on power increases with stage 1 ported and polished ls6 heads over stock ls6?
Old Apr 8, 2010 | 04:33 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Very good preliminary numbers for your set-up
I would say that you can safely expect 20-25(Max) RWHP and be solidly in the 11's, and if you can beg,plead,bargin for someone to lend you a drag pack - I could very see mid 11's for your set-up
Keep us posted as to the results
Thanks,Matt
Old May 15, 2010 | 11:42 AM
zohsex's Avatar
zohsex
Nice numbers this thread helped me out i have a Ms3 cam i pulled from my truck and was wanting to know some numbers and i found them and now i will soon be putting it in my Z along with a head swap and a fast 92/92
Old May 16, 2010 | 08:22 PM
Nate B's Avatar
Nate B
I finally put my heads on yesterday so as soon as it gets soon I will post my new numbers.
Old May 16, 2010 | 08:41 PM
0331MARINE's Avatar
0331MARINE
Make sure you post new #'s. Im about to get a set of 243's and send them off.
Old May 17, 2010 | 05:50 PM
Nate B's Avatar
Nate B
Will do.
Old May 22, 2010 | 05:11 PM
Nate B's Avatar
Nate B
Ok, I got tuned yesterday and put down 447/391 on a dynapack dyno after installing tsp stage1 ls6 heads. Im not really sure how this compares to a dynojet but I did 424/371 a ms3 cam only on stock ls6 heads.
Old May 22, 2010 | 05:17 PM
0331MARINE's Avatar
0331MARINE
I would find a Dynojet and run it. I bet it will be higher. Still not bad for a Stage 1 port. Thanks for the numbers!
To Ms3 dyno numbers
