torque tube tunnel insulation
Old Apr 12, 2010 | 10:33 PM
cruisemon's Avatar
cruisemon
Default torque tube tunnel insulation
Has anyone ever insulated the torque tube tunnel and the top of the tunnel plat to cut down heat and noise transfer? What did you use?
Charlie
Old Apr 15, 2010 | 10:59 PM
dreamscometrue's Avatar
dreamscometrue
Check out Madvette. He is in Murfreesboro and sells insulation kits for the interior. Maybe he could get you some material to the size you need and put it up there. How is the project coming with the tunnel plates?
Old Apr 16, 2010 | 07:29 AM
cruisemon's Avatar
cruisemon
Very slowly. We're moving our office this afternoon and tomorrow and the site prep for the new office over the last month has about kicked my bony old @$$ working seven days a week. I may get to take a day off the week of 4/26,
And thanks so much for the project donor tunnel plate. I have the insulating material to put in the tunnel and on the tunnel plate (well, at least I have some material I think I can use). I was hoping someone had info on torque tube to tunnel clearances. The material I plan to use is about 1/2" thick and if there isn't at least another inch clearance to the torque tube I'd be concerned about adhesive coming loose, wrapping on the torque tube and doing some serious damage. It may be better to just do the plate and forget doing the tunnel.
Charlie
Old Apr 16, 2010 | 09:55 AM
TNX ZORA's Avatar
TNX ZORA
I'm thinking the torque is not spinning only the shaft inside so it's not going to wrap up insulation.
Old Apr 16, 2010 | 10:53 AM
rickko's Avatar
rickko
How about gluing insulation to the tunnel plate?
..rickko..
Old Apr 16, 2010 | 10:58 AM
Tigershark3's Avatar
Tigershark3
When I replaced my radio bezel/console due to damage awhile back I covered the interior where the console sits with frost king insulation. It's cheap, fits well and seemed to cool the interior somewhat. Not a perfect solution but one that worked for me. $.02
Old Apr 16, 2010 | 11:37 AM
BlueThunder2000's Avatar
BlueThunder2000
Vettaholic
I did three mods to keep heat out:
- did the popular "frost king" mod inside the car (many threads on the subject, just do a search)
- Installed this: http://www.lgmotorsports.com/catalog...oducts_id=1564
and this:
http://www.lgmotorsports.com/catalog...oducts_id=1565
(extremely efficient heat barrier and a quality product IMHO)
- made a sort of blanket out of glass wool to put inside between torque tube and tunnel, while the drivetrain was out for the head/cam/tranny job
Alll together it works fine, I do not systematically need to start A/C now
Patrick
Old Apr 16, 2010 | 12:12 PM
yooperod's Avatar
yooperod
I tried the diy insulating with foil faced ,did the floor. and noticed little differance
then installed a ceramic coated plate, (Elite iirc)
that made a big differance in the heat in the console
To torque tube tunnel insulation
