[Z06] Shock Question 2002-2004
Old Apr 15, 2010 | 06:52 PM
wallifishrmn's Avatar
wallifishrmn
Default Shock Question 2002-2004
Are the shocks identical on the 2002, 2003, & 2004 Z06's??
Front: 10339944 AKW
Rear: 10339945 AKX
Old Apr 15, 2010 | 07:18 PM
uberC5's Avatar
uberC5
04Z's are different front and rear
BTW, 01's fronts are the same as 02-03, but rear is different.
So:
01-03 same fronts
01 rears unique
02-03 same rears
04 unique front and rear
Here is a good overall discussion of the C5Z
Old Apr 15, 2010 | 07:29 PM
CorvetteRanch's Avatar
CorvetteRanch
Buy coilovers You can get Callaway/Eibach R2 Pro street/track for 1500 bucks from Tire rack. Awesome shocks with remote reservoir.
Old Apr 15, 2010 | 10:56 PM
wallifishrmn
Are my part numbers correct? I saw 2004 shocks for sale on the forum and they had the part numbers I listed--therefore I must be wrong. What are the right numbers?
Old Apr 15, 2010 | 11:03 PM
MTPZ06's Avatar
MTPZ06
You may want to hit up Gene Culley (GM Parts House) if your in the market for stock shocks. The '04's are pricey, so most go with the '09 shocks as they are a direct bolt on.
Old Apr 15, 2010 | 11:20 PM
LT1driver's Avatar
LT1driver
c6 shocks not a good choice if car lowered, otherwise ok.
Old Apr 16, 2010 | 02:47 AM
wallifishrmn
Are these the correct numbers for the shocks:
front ac delco 580-122 GM 22064825
rear ac delco 560-200 GM 10431991
Why are the front shocks so expensive?
Old Apr 18, 2010 | 04:18 AM
longdaddy's Avatar
longdaddy
you should be able to find a set of 04 Z06 shocks for under $500. I got a hit on the first page of google results - not going to link, don't think it's a forum vendor.
Old Apr 18, 2010 | 11:59 AM
Edmond's Avatar
Edmond
The popular thing to do, I'll probably end up doing it myself as well, seems to be going with the C6 Z06 shocks. Gene does advertise a set of 4 for less than $300, IIRC.
Old Apr 18, 2010 | 12:18 PM
007Duc's Avatar
007Duc
I cannot find what you are talkig about.
Old Apr 18, 2010 | 02:04 PM
Edmond's Avatar
Edmond
Here you go:
http://www.lgmotorsports.com/catalog...?cPath=342_230
Old Apr 18, 2010 | 02:17 PM
MTPZ06's Avatar
MTPZ06
Me neither...but I did see that Tire Rack has Koni FSD's for $599.
Old Apr 18, 2010 | 04:51 PM
TXGS507's Avatar
TXGS507
do a search for "toque"... the guys name is Mark, he has a low mileage set of shocks from his 04 Z06... perfect set for $100.00! (Dallas TX) or you can have mine off of my 01 for $75.00... GL with search...
To Shock Question 2002-2004
