Rag top issues
Old Apr 21, 2010 | 11:42 PM
El original's Avatar
El original
Default Rag top issues
Hello CF members, question, on my convertable roof material I have issues with shiny or flashing spots where it seems the material is crushed or laying in another direction causing the shiny areas. How can I remedy this and have the rag look uniform again? Any ideas? I bought the car like this. Maybe it was put away wet or? Greetings, Rob
Old Apr 22, 2010 | 12:02 AM
TNX ZORA's Avatar
TNX ZORA
Possibly there is some substance in those areas and a thorough cleaning of your top would bring back uniformity. I've never seen exactly what you're describing so this is a "best guess" response.
Old Apr 22, 2010 | 07:32 AM
dougbfresh's Avatar
dougbfresh
Normal wear-as you store the top it rubs.
Old Apr 22, 2010 | 12:41 PM
Daw9-02Vert's Avatar
Daw9-02Vert
Probably the previous owner stored the top down for extended times. You always want to put it back to it's closed position when not using. As stated above it rubs when stored. Small marks like that go away for me when I wash - use a recommended top cleaner and protectant - then let dry thoroughly before you even think about putting it down. But then again mine only has 11k miles on it. Good luck!
Old Apr 22, 2010 | 01:28 PM
DeeGee's Avatar
DeeGee
I think it may just be wear and tear. I have the same issue but never found a good solution. It improves after using Ragg Top but it returns quickly.
Old Apr 22, 2010 | 01:39 PM
dougbfresh's Avatar
dougbfresh
My solution is LEAVE THE TOP DOWN AS MUCH AS POSSIBLE. That's what Vert's are for.
Old Apr 22, 2010 | 05:18 PM
Cardinal Flyer's Avatar
Cardinal Flyer
Old Apr 23, 2010 | 09:07 AM
WvCorvette's Avatar
WvCorvette
Same here...Ragg Topp does help for awhile.....
Old Apr 23, 2010 | 12:51 PM
El original
Thanks for the response, guess I will have to live with it. I drive almost exclusively with the roof down. Guess it is wear from being in storage while driving it rubs. Just that I have not seen it on other verts. Greetings, Rob
Old Apr 24, 2010 | 07:45 AM
RSchleder's Avatar
RSchleder
I agree, buy a Ragg Top kit and clean and treat your top per the instructions. You'll see a major improvement. Good luck, Ron
Old Apr 24, 2010 | 07:53 AM
Phanni's Avatar
Phanni
Since you leave the top down a lot, consider using some padding in the folds (of the soft top) while driving. Something as simple as a bath towel placed in the folds of the top will cushion the vibrations and ensuing wear points.
Old Apr 24, 2010 | 08:05 AM
SSWEET's Avatar
SSWEET
Old Apr 24, 2010 | 12:01 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Get a horsehair brush and some Ragg Topp cleaner and protectant. Follow the directions and you will not have the problem (unless the canvas is actually frayed or worn). I had the same exact issue, just did mine Thursday and it looks brand new again; black top, 14.5K miles, '04.
To Rag top issues
