[Z06] Header Primary Tube size Question
Old Apr 22, 2010 | 11:07 PM
81c3's Avatar
81c3
Default Header Primary Tube size Question
I have an older set of headers on my car. They're TPIS Lt's. I also have Random Tech hi flow cats and an X pipe. The primary size of my headers is 1 3/4" I was think ing of getting a new set or a slightly used set. Should I go up to 1 7/8" primaries? I just put a Torquer V2 cam in it and dynod 411/380. Im thinking I should be able to improve my torque with the 1 7/8". Would this be wise or should I just leave well enough alone?
Old Apr 22, 2010 | 11:17 PM
MTPZ06's Avatar
MTPZ06
I don't think it's worth the time and expense. If you go with Heads and a Fast 90/90 or go FI, then it may have some merit.
Old Apr 23, 2010 | 01:19 AM
striper's Avatar
striper
Unless you are doing more mods like heads, compression or forced induction, the 1 3/4" is ideal for what you have. Going larger might actually kill low end torque because the larger tubes would slow down exhaust flow without further mods. You need to keep the exhaust flow speed up. Besides even if it would provide any increase, the performance difference wouldn't be enough to justify the expense and effort.
Old Apr 23, 2010 | 08:47 AM
AU N EGL's Avatar
AU N EGL
for about the same amount of money a fast 92/92 and dyno tune will give you more bang for your buck then 1 7/8 headers, at this time.
Old Apr 23, 2010 | 09:55 AM
81c3's Avatar
81c3
Thanks guys!
To Header Primary Tube size Question
