FRC Weather Strip Problem--need help
Old Apr 27, 2010 | 09:01 PM
TORRED's Avatar
TORRED
Default FRC Weather Strip Problem--need help
Due to my height (6ft 7in) and age (67) I tend to rub against the weather striping on my FRC roof when I get in it. It's to a point that it will not stay in the roof channel any longer. It was not glued in by the factory, the roof channel held it in as it does on the passenger side. Can I glue it in with weather strip cement with out causing any future problems or is there so other fix that i am not aware of? Should I buy a complete new strip and replace the old one that will no longer hold?
Old May 4, 2010 | 07:27 PM
T_Terrazo's Avatar
T_Terrazo
I have weather striping coming out on both sides I'm afraid. I even get drips of water into the car if it rains (*sigh*). Can anyone post some help on replacing weather striping?
Old May 4, 2010 | 07:47 PM
RJRSW's Avatar
RJRSW
From the service manual:
Weatherstrip Replacement - Lift Off Panel
Remove the roof lift off panel.
Remove the screws from the ends of the weatherstrip.
Remove the weatherstrip from the weatherstrip retainer.
Clean the surface with 3M™ adhesive remover P/N 8984 or equivalent.
Installation Procedure
Apply a 6.0 X 40 mm (0.25 X 1.5 in) bead of sealer GM P/N 12345739 Canadain P/N 10953541 to the front and rear corners of the retainer as shown in the illustration.
Apply the bead of sealer to the roof.
Apply the bead of sealer to the retainer.
Apply the bead of sealer to the ends of the retainer.
Important
Do not touch the adhesive backing on the new weatherstrip.
Remove the protective backing from the foam tape on the ends of the new weatherstrip, or install two sided tape 3M™ P/N 06377 or equivalent to the ends of a reused weatherstrip.
Install the weatherstrip into the retainer using a nylon spatula or your fingers. Start at the forward edge and work rearward.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the screws at the ends of the weatherstrip. Hold the weatherstrip to prevent the weatherstrip from rotating. Tighten
Tighten the side weatherstrip screws to 3 N·m (27 lb in).
Install the roof panel.
Old May 4, 2010 | 07:55 PM
HawkIVette's Avatar
HawkIVette
Important
Notice
:o Uh.... I think OP states FRC weatherstrip..........No Roof Panel to remove.
Old May 4, 2010 | 08:23 PM
RJRSW's Avatar
RJRSW
My initial response was to the request by T_Terrazo in the second response to the thread for instructions.
Weatherstrip Side Retainer Replacement Hardtop
Removal Procedure
Remove the weatherstrip.
Remove the weatherstrip retainer.
Remove the blow out clip, if reusing the clip.
Clean the mounting surfaces.
Apply a bead of sealer to the blow out clip (2).
Peel the protective cover from the foam tape on the back of the retainer.
Position the clip to the back of the retainer.
Apply a bead of sealer (1) to the area where the clip will contact the reveal molding.
Apply, outboard of the two screw holes where the retainer bends, a continuous bead of sealer (5) to the applique and the reveal molding.
Replace any stripped, broken or improperly seated screws.
Install the windshield weatherstrip side retainer.
Notice
Install the screws mounting the windshield weatherstrip side retainer to the pillar. Tighten
Tighten the side retainer to applique screws (4) to 2.5 N·m (22 lb in).
Tighten the side retainer to windshield pillar screws (4) to 2.5 N·m (22 lb in).
Tighten the side retainer to roof screws (3) to 1.4 N·m (12 lb in).
Apply sealant and install the weatherstrip. Refer to Weatherstrip Replacement .
Weatherstrip Replacement Hardtop
Removal Procedure
Remove the push-in retainers securing the weatherstrip to the lock pillar.
Pull the weatherstrip with its retainer from the lock pillar weatherstrip retainer.
Remove the push-in retainers (1,2) securing the forward end of the weatherstrip to the reveal molding and the hinge pillar.
Pull the weatherstrip with it's retainer from the reveal molding.
Clean the surface of old sealant material.
Apply a 50 mm (2 in) bead of sealant (1) GM P/N 12345097, or equivalent, down the middle of both the weatherstrip retainers at the upper rear corner of the door opening.
Apply a bead of sealant (2) to the lower 50 mm (2 in) of the lock pillar weatherstrip retainer (1) and 50 mm (2 in) down the lock pillar.
Apply three parallel 50 mm (2 in) long beads of sealant (1) to the forward end of the door opening weatherstrip retainer and to the rear edge of the reveal molding.
Remove the protective tape from the back of the weatherstrip.
Insert the weatherstrip into the weatherstrip retainers.
Start at the rear upper corner.
Insert the upper/outer edge of the weatherstrip first.
Install the weatherstrip retainer securing the weatherstrip to the lock pillar.
Install the push-in retainers securing the weatherstrip to the lock pillar.
Install the weatherstrip retainer (1) securing the weatherstrip to the hinge pillar reveal molding.
Install the push-in retainers (2) securing the weatherstrip to the hinge pillar.
Old Jun 24, 2013 | 11:01 AM
Bholifield4901's Avatar
Bholifield4901
Is there anyplace to buy the weatherstrip that is cheaper than $300-$400?? I have a few tears in my driver side and am hearing a lot of road noise.
Old Jun 24, 2013 | 01:01 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
depending on how much your head hits it, you can use some silicone to hold it in place. I had to do that on my STS Caddy. It didn't have any glue on it's weather stripping either and was always coming off.
To FRC Weather Strip Problem--need help
