Correct idle speed?
Old May 1, 2010 | 01:33 AM
El original's Avatar
El original
Default Correct idle speed?
Had my stock MN6 vert out for a spin tonight and thought it was idling rather fast 850 rpm. At best it idles at 800, I thought it should be about 750 rpm. Is this normal? I am a new C5 owner, if it is high how does one go about adjusting it? Greetings, Rob
Old May 1, 2010 | 02:00 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
My A4 idles around 500 RPM when warm.
dougbfresh's Avatar
dougbfresh
You can't adjust it with a tuner. 800 is about right.
Old May 1, 2010 | 11:41 AM
corvettedaddy11's Avatar
corvettedaddy11
Old May 1, 2010 | 12:28 PM
Garrett W's Avatar
Garrett W
All cars are different. What does it usually idle at? Mine sits at about 600, but thats how it is tuned... If yours usually idles at 500, and then was idling at 800, maybe something is up, but if it usually is 800, then I think its fine...
To Correct idle speed?
