DIC codes - new to C5's
Old May 1, 2010 | 06:16 PM
qipman's Avatar
qipman
Default DIC codes - new to C5's
Hey guys,
I finally got around to looking at the DIC codes on my C5. I ahve only had this since March and am new to C5's. I looked these codes up and found "battery faults" and "loss of communication with the BCM/IPC". These are the only codes that came back, and the battery is relatively new and not sure what the loss of communication is referring to as everything is working in this car spot-on.
Just wondering if anyone can provide some insight on this and thanks!
A0-LDCM
B2282 H
B2284 H
U1016 H
U1096 H
A1-RDCM
B2283 H
B2285 H
U1096 H
U1016 H
Old May 1, 2010 | 07:05 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I see they are all "H" history codes, Delete them and see if they come back, They may have been there for some time.
Mr.Bill
Here is how to delete them.
http://www.stengel.net/diccodes.htm
Old May 1, 2010 | 07:15 PM
TN Vette's Avatar
TN Vette
Mr.Bill
mine had a couple of those after I disconnected/reconnected the battery to inspect the battery tray for damage.
Old May 1, 2010 | 07:35 PM
Bill Vett's Avatar
Bill Vett
Check Bill Curlee's post in the tech section. Search "accordian" in that thread. Check the wires in the Accordian tube on the drivers door. There may be a wire that's grounding. Those codes are left door and right door control modules. The wiring for both doors passes through the drivers door.
Old May 2, 2010 | 01:52 AM
DeeGee's Avatar
DeeGee
The U codes often pop up with power glitches that you wouldn't even notice.
If the door locks and windows are working OK I wouldn't mess with them.
Clear down the codes and see how you go.
Old May 2, 2010 | 03:48 AM
qipman's Avatar
qipman
Thanks everyone!
To DIC codes - new to C5's
