Remote Transmitter Problem
Old May 4, 2010 | 12:11 AM
snpperhd's Avatar
snpperhd
3rd Gear
Default Remote Transmitter Problem
I'm having a weird problem with my remote. It began when my remote became unsynced...so I synced it by using the standard remedy (holding lock/unlock), but I noticed the remote started acting funny...it began to unlock my car without being touched. I don't utilize the passive function, so that shouldn't be an issue. Also, the sync only lasted a day. So I repeated the sync sequence, but it continues to unsync. I replaced the battery, still no fix. I opened the remote and inspected the board and contacts, but everything looks good. Any ideas?
snpperhd
Old May 5, 2010 | 10:08 AM
snpperhd's Avatar
snpperhd
3rd Gear
No ideas? I'm surprised this hasn't happened to others. Guess I'll replace the fob.
snpperhd
Old May 5, 2010 | 11:42 AM
corvettedaddy11's Avatar
corvettedaddy11
Hey dude give TSTAR a shout mine was not working an i sent mine to him an he fixed mine !! Alot cheaper than buying a new one!!
Old May 5, 2010 | 11:45 AM
Sargevette's Avatar
Sargevette
As a new C5 owner I was reading in the manual a procedure to sync remotes. Might check it out before you buy another one. I have to get another key and fob.
Most likely it is the fob gone bad. I had that happen on my '00. Once I replaced the fob, everything worked as it should.
Old May 6, 2010 | 09:46 AM
snpperhd's Avatar
snpperhd
3rd Gear
Thanks for the replies...yeah, I've tried the official sync procedures multiple times, so I'm pretty much convinced it's a bad fob. I've already sent TSTAR an email (thanks corvettedaddy11)...I'll post any progress.
snpperhd
Old May 6, 2010 | 01:05 PM
corvettedaddy11
Old May 7, 2010 | 05:23 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
snpperhd
You did?
Old May 7, 2010 | 07:04 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Turn the PASSIVE switch to "OFF", otherwise it will lock when you get far enough away and UNLOCK when you get close to the Vette -
Most of us hate this function and switch it to off, 00-04 did not come with this option on the remote
Thanks,Matt
To Remote Transmitter Problem
