Oooops, Removed Front Emblem ...
Old May 4, 2010 | 07:08 PM
Mudvayne387's Avatar
Mudvayne387
Default Oooops, Removed Front Emblem ...
I removed my rear corvette emblem without a problem, so I figured to complete the "clean look" I would remove the front. Everything was going along just fine when suddenly I realized there were two small holes where the emblem was. I was quite surprised because it seemed very unnecessary to have pins holding the emblem on. I did a bit of searching and found out others have discovered the same mounting holes as I did. Either way, the emblem was 3/4 off so I went through with it. I love the look of the front without the emblem, but those two small holes are killing me (close up)
So...
Has anyone painted their emblem the same color as their car, or does anyone have any suggestions for after-market front emblems ?
Thanks, any help is greatly appreciated.
Old May 4, 2010 | 07:14 PM
SFL_driver's Avatar
SFL_driver
If you are going for the clean look you should see what you can do about getting the holes filled.
Old May 4, 2010 | 07:27 PM
GHL4505's Avatar
GHL4505
I did the same thing, but then made and adjustment with a razor blade and replaced the emblem to cover the holes. It's a little cleaner look
Old May 4, 2010 | 08:04 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
Looks like a c6 emblem on a c5 now.
Old May 4, 2010 | 08:53 PM
jdmvette's Avatar
jdmvette
Night Owl for life
if you didn't know any better.
Old May 4, 2010 | 08:54 PM
damilleniumboy's Avatar
damilleniumboy
Old May 4, 2010 | 09:18 PM
BenC5's Avatar
BenC5
I heated up the checkered flag and the red flag and took them out as they are inserts.
Looks much better on my Navy Blue Metallic. I only wish I could ditch the thing altogether but have nothing to cover the holes with.
Old May 4, 2010 | 09:29 PM
GHL4505's Avatar
GHL4505
Actually, I think all the generations of corvette had just the crossed flags. It was just the C5 that had that silly oval attached that makes it a pain to keep clean. The C6 went back to the crossed flags sort of.
Old May 4, 2010 | 09:51 PM
PewtVette's Avatar
PewtVette
I think the 'silly oval' looks way cool. Much better than the cartoony C6 emblem pictured above.
Old May 4, 2010 | 09:54 PM
Bat Man's Avatar
Bat Man
C4 had the first "silly oval"
Old May 4, 2010 | 09:55 PM
Bat Man's Avatar
Bat Man
Old May 4, 2010 | 10:11 PM
Mudvayne387
Ahh, I didn't realize that. I will have to give that a try.
Thanks for all the responses !
Old May 4, 2010 | 10:17 PM
GHL4505's Avatar
GHL4505
I forgot about the "silly circle" on the C4. My friends kept asking why I had a T-Bird emblem on my 89 Corvette. All silliness aside, my C5 emblem is a heck of a lot easier to polish around now.
Old May 4, 2010 | 10:19 PM
That really does look pretty good IMO.
Old May 4, 2010 | 10:39 PM
PewtVette's Avatar
PewtVette
Yeah, I could slide with that.
Old May 4, 2010 | 11:11 PM
olbear1962's Avatar
olbear1962
Old May 5, 2010 | 12:37 AM
silver408z's Avatar
silver408z
I personally like the c5 emblem and I also think its cool GM changes it up with every generation.
Old May 5, 2010 | 06:31 AM
dieseldave56's Avatar
dieseldave56
Default Quick silver
I painted my 2001 Z06 c5 emblem to match
To Oooops, Removed Front Emblem ...
