Trick Flow build Guesstimates?
Old May 11, 2010 | 09:27 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Default Trick Flow build Guesstimates?
2003 ZO6
64k
1 3/4 ARH headers and X pipe
Blackwing
Carbon fiber bellow 102mm
Fast 102 mm
Fast fuel rails
LS2 Throttle body
42lb injectors
VA speed Cam 230 ish 600 ish 113 ish
Center force DF stock flywheel
Installing Trick flow 215
HS 1.7 RR
lS7 lifters
LS2 lifter trays
ARP head bolts
GM Gaskets
Brain @ VA speed is installing, Shawn is milling/cleaning the heads and Ed is tuning, Car currently puts down 427 rwhp 397 rwtq after multiple runs sae correct on the heartbreaker.
I know with out the exact cam specs it will be hard to calculate but what do you think it will put down.
Im hoping for 480/440
I have a friendly bet with my buddy
Mario
Old May 12, 2010 | 12:21 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
500rwhp 430rwtq is my guess
Old May 12, 2010 | 01:37 PM
Sargevette's Avatar
Sargevette
Old May 12, 2010 | 03:26 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
472rwhp/425rwt
Old May 12, 2010 | 04:31 PM
SUPERCRUZ's Avatar
SUPERCRUZ
I am runnig a similar cam setup, upper 230s, .600+ lift, 113 LSA. You do not say if you are running LTs and hi-flow cats. Your exhaust setup will make a difference. If you are running LTs, I would say you will come in somewhere between 475 - 500 RWHP and approx 425 RWTQ with your setup. Ed is a great tuner. He will get you running right on the street. Tuning for max HP/TQ is one thing. Tuning to have the car run good on the street is a whole different ball game. Good luck with it and hold on.
Old May 12, 2010 | 04:53 PM
MACKASH's Avatar
MACKASH
Old May 13, 2010 | 05:49 PM
mariofromnewyork
Car has stock flywheel.
I have ARH headers & x pipe.
Ed will make it right for sure.
Mario
To Trick Flow build Guesstimates?
