Problem with my Headlights - Need Advice
Old May 12, 2010 | 10:37 PM
iceman82nd's Avatar
iceman82nd
Default Problem with my Headlights - Need Advice
So I recently purchased a 02 Coupe and have only one issue with the car. it runs perfectly fine and smooth. The only issue is the headlights are not synchronized and dont work properly. First off when switching to accessory the fog lights dont come on but the lights flip up. Sometimes only one will flip up, and when you flip the switch off the other light pops up and the other one goes down. My vette is confused. And when i turn it off you can hear a grinding noise where the light is for a good 5-10 seconds. Any advice please let me know.
Thanks,
Joe
Old May 12, 2010 | 10:50 PM
MG RED 99's Avatar
MG RED 99
As far as your headlight being possessed I don't know. As far as the grinding noise, you probably have a slightly stripped motor gear, and will need the gear to be replaced. Do both sides because he other will soon go as well. Go with the brass style versus the oem plastic. The bad gear shouldn't have anything to do with your fog/headlight flip flop. This could be in the turnsignal lever, but one of the other pros will have to chime in. I also assume that the reason only one of the headlights pops up is also due to the bad gear.
Old May 12, 2010 | 11:50 PM
iceman82nd's Avatar
iceman82nd
Thanks for the input. Just rather see if you guys can figure it out than to take it to a mechanic though.
Old May 13, 2010 | 12:46 AM
DeeGee's Avatar
DeeGee
You have a stripped headlight gear Joe. Those are classic symptoms.
Run down to the headlight gear section of this sticky and it'll tell you all you need to know. I went with Rodney Dickman's kit. He designed a nice little bracket that fixes the headlight motor case back together.
http://forums.corvetteforum.com/c5-g...ngths-etc.html
I had one go early on and the dealer replaced the gear under warranty. So far so good and I've not had any more problems. I disabled the automatic function (twilight sentinel) so I only use the lights when I need them. I also have Euro headlights which are heavier than stock so I'm expecting a failure at some stage. I have two brass gears ready to go in at any sign of trouble.
Those who have done the fix say the first one is hardest and the second one would be easier with the practice. You might want to bite the bullet and do both at the same time.
Old May 13, 2010 | 10:50 AM
iceman82nd's Avatar
iceman82nd
Is this the reason for why, in accessory mode the lights pop up rather than the fog lights turn on? If i replace the motors, i know the grinding will go away but will they both be synchronized then?
Old May 13, 2010 | 03:18 PM
DeeGee's Avatar
DeeGee
We often see associated problems here. Replace the gears and see what you have. I'd bet you'll fix all the problems with the gears. If not, we can troubleshoot the others.
Old May 13, 2010 | 03:42 PM
Chicago1's Avatar
Chicago1
When I replaced my gears I had the same synchro issue. What solved mine was I turned the headlights on so one was up the other down. I manully turned the **** on the headlight motor that was in the down position to the up position. I went and cycled the heallight switch inside the car and bamn they got synschored up.
Old May 17, 2010 | 05:31 PM
MG RED 99's Avatar
MG RED 99
Good advice and that sounds logical.
To Problem with my Headlights - Need Advice
