[Z06] Track / Road Race first mods?
Old May 17, 2010 | 11:15 PM
C5nNC's Avatar
C5nNC
Default Track / Road Race first mods?
Bone stock 02 Z06. Will be tracking a few times a year. What are the suggested first mods to prepare for it? input regarding oil, transmission and power steering fluid coolers would be beneficial. Would prefer suspension, brakes and cooling suggestions before engine mods.
Old May 17, 2010 | 11:35 PM
uberC5's Avatar
uberC5
I'm going thru the same thought processes. Read THIS if you haven't already.
Old May 18, 2010 | 12:25 AM
ptindall's Avatar
ptindall
#1 Factory fill Mobil One is fine, but overfill one quart before going on track. GM even says to do this. Do it. It might save you an engine rebuild.
#2 Track alignment. Stock alignment will push and chew up your tires.
#3 Track brake pads. Stock ones will fade in short order.
As for coolers, the car has a power steering fluid cooler stock. I wound up getting power steering fluid overflowing a bit from my resevoir anyway so I switched to RedLine power steering fluid and now it's fine. Next up is an oil cooler which is a good idea if you drive hard but lots of people track their cars without them. Not required right away. Check the roadrace section for tons of threads about them. IMO the trans cooler is the last you need if you drive really really hard or have more power than stock. If your trans is overheated, it will pop a message up on your DIC to let you know. I have never gotten the message so I see no reason to buy a trans cooler. They cost a friggin fortune.
Go hang out in the autocross/roadrace section of the forum under "General Corvette." All the info you could ever want is over there if you search and ask.
Old May 18, 2010 | 07:38 AM
AU N EGL's Avatar
AU N EGL
Road course mod list:
1. Contact patches.
Brake pads, Brake fluid change
Brake cooling
Seats and harness
Tires.
2. aggressive street alignment
3. then Bigger cooling
bigger Radiator, Oil cooler, Trans cooler
PS cooler if you dont have one.
Then nothing but seat time and more seat time.
Notice no HP mods. Most ppl can not drive a stock vette to 60% of the cars capabilties any way.
yes HP mods are sexy as hell, but contact patch mods and seat time make you a far better driver
Old May 18, 2010 | 10:25 AM
kflee's Avatar
kflee
1. Contact patches.
Brake cooling
Seats and harness
Tires.
What he said
Old May 18, 2010 | 11:14 AM
63Corvette's Avatar
63Corvette
1. Contact patches.
Brake cooling
Seats and harness
Tires.
To Track / Road Race first mods?
