[Z06] Electrical Problem?
Old May 18, 2010 | 04:06 PM
turbo03cobra's Avatar
turbo03cobra
Default Electrical Problem?
Has anyone ever heard of:
I put the key in the ignition the gauges do the full sweep then I turn the car and nothing works in the cluster, or the radio for that matter. The only thing working is my gauge pod that has an AEM wideband and Cobalt Digital boost gauge. Never had this problem before and just started the other day. Also now the Active Handling and Trac System lights are blinking and will go away if turn the car off and back on.
What in gods name could that be? I just put in an AEM Wideband and prior to that I never had any problems?
Old May 18, 2010 | 04:11 PM
TXGS507's Avatar
TXGS507
This is where i would start....
Old May 18, 2010 | 04:15 PM
turbo03cobra
The AEM just taps into a fuse, would that relate to what seems to be all the problems?
When you start the car now and none of the gauges work you can turn the key backwards slightly and then all then the cluster will work and so will the radio??
This is weird..
Old May 18, 2010 | 04:31 PM
TXGS507's Avatar
TXGS507
A long read... but worth it... If nothing else PM Bill, he is a "Wizard" on these cars electrical systems..
http://forums.corvetteforum.com/c5-t...tion-long.html
Old May 18, 2010 | 04:38 PM
turbo03cobra
thank you I sent him a PM
Old May 18, 2010 | 05:26 PM
TXGS507's Avatar
TXGS507
No prob... he will figure it out... Make sure you post up your find... GL
Old May 18, 2010 | 06:44 PM
KCvetteowner's Avatar
KCvetteowner
Just disconnect your battery for 30 minutes. Reconnect it and walk away from the car for at least 15 minutes. Don't touch anything. The computer systems have to boot up in sequence and if they don't, the car will do stupid stuff until it goes thru a restart.
If your battery is low you need to charge the battery while it's not connected to the car. Once fully charged, connect it back up and don't do anything to the car for 15 minutes.
I see this all the time...
Old May 18, 2010 | 07:42 PM
TXGS507's Avatar
TXGS507
I too have heard of this but i am no expert...therefore did not want to mis inform.. I say try this...
Old May 18, 2010 | 07:48 PM
turbo03cobra
It could be the steering lock sensor going out I think, but I will try the battery trick. Everything seems to be good right now. Thanks guys!
Old May 18, 2010 | 11:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try this:
Disconnect your battery and clean the terminals and TORQUE them to 11 ft/lbs.
If that doesnt resolve the issue, my best guess would be to service your ignition switch using this post:
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Let me know how you make out.
BC
Old May 19, 2010 | 03:46 PM
turbo03cobra
Thank you sir I will be trying this and will get back to the thread tonight!
Old May 19, 2010 | 03:57 PM
TXGS507's Avatar
TXGS507
Ask and "ye" shall recieve...
What an awesome support group.... Keeps me coming back daily!
To Electrical Problem?
