Please HELP!!! ASAP
Shortly after I started noticing that the car lost a LOT of power especially in lower rpms, The A4 became much less responsive,(a lot of lag) and sometimes the car would jerk forward without even me touching accelerator. The check engine light came on, first blinking and then stayed on. I did several 0-6- runs (on a closed road) and found that I lost almost 1 1/2 second. (it was 5 flat now it is 6.5) I plugged my diablo predator tuner and red the code, it showed the following code PO300 misfire!? I took the tune of and restored my backup tune and then the vert did not even have power to spin the wheels. It felt more like Honda civic acceleration. The milege went down big time as well!!!
I have a dual cone CAI, and a factory diablo tune in the car otherwise stock. The muffler guys called me earlier during installation and told me that the spark plugs and wires looked brittle and recommended getting new ones. I got only wires but decided to wait with plugs for a few weeks.
Tomorrow morning I am going back there with a lot of questions!!!
I spend 1500$ to gain HP, not to loose it!!! I need you guys opinions and advises as to what it is and what I should do
Thanks in advance for you help!!!
Victor
I heard that headers make the a/f leaner, Is there any way to use the diablo predator to at least temporarily fix the problem (like changing a/f mixture to richer?) just so I can get to the shop
what did you do with the o2 sensors? Move back to front and delete the rear? Put all 4 back in same place?
my guess is the o2 sensors are wrong like you mentioned
after i installed me lt's,i drove my car for 3 weeks before getting it tuned.never threw a code and always had more power than the stock exhaust did.
#2 You probably have a cracked spark plug. Look closely at #6 and #7
#3 Bad plug wire
NOT IN THE TUNE
btw If you spent $1500 for OBX installed you got ripped. Sorry
My money is on the fact that the muffler shop crossed these wires. It's a common mistake.While a full tune should be done, installing headers should not make the car run this poorly. When mine were installed, it was about 2 weeks before I had it tuned, and it ran fine.
Something is a miss mechanically!!! Good luck getting it straightened out.
However the original muffler shop guys told me that they felt that there was more to the problem that just absence of cats.
So the plan for now is to put in cats and see what happens.
I very much regret getting all this started(headers, pipes etc) Reliability comes first, and now god knows what all that did to my car.
extremely frustrated.
The cats may have clogged but highly unlikely.
They must have pulled the codes and found a P0302 if they told you it was cyl #2.
My bet is they cracked #2 spark plug. I don't think they needed to remove the coil packs to install the headers but I'm sure they removed the wires and plugs. This is where I would look first.
I would be concerned that they had to spend this much time on your car and they still don't have it fixed.
Just my 2 cents.
