steering wheel puller????
Old May 20, 2010 | 08:29 AM
Gitusum's Avatar
Gitusum
Default steering wheel puller????
I am looking for info on what type of steering wheel puller is used to pull the steering wheel off.pics would be appreciated. i dont think the standard puller works since it is threaded. any help would be great.
Thanx
Rick
Old May 20, 2010 | 08:56 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Thanx
Rick
You need to find one that has J-hooks. I used three different ones including a snap-on. Let it sit overnight with pressure and still couldn't get the wheel off. Finally I ended up taking the steering column out with the wheel and used a air hammer,lol. Hopefully yours will not be that tight.
Old May 20, 2010 | 10:53 AM
Gitusum's Avatar
Gitusum
so basically i am better off taking it to the stealership?
Old May 20, 2010 | 11:18 AM
HowlinC5's Avatar
HowlinC5
There are usually 2 threaded holes in the wheel for using the standard steering wheel puller. I'd be scared of the hook kind breaking the steering wheel.
Old May 20, 2010 | 11:25 AM
Gitusum's Avatar
Gitusum
there are no threaded holes in my wheel
Old May 20, 2010 | 11:47 AM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Here's what kind of puller and legs are called for in the instructions I have for steering wheel removal:
A Steering Wheel Puller (Kent-Moore tool # J1859-A, or KD Tools tool # 2291)
A set of Steering Wheel Puller Legs (Kent-Moore tool # J42120, or KD Tools # 3510)
These legs are the J-hook legs and have no threads. As well, the wheel has no threads either. As for a puller, I borrowed a standard puller from a mechanic at work and my J-hook legs worked fine with it.
I found the proper legs locally at NAPA. They had the KD Tools set, #3510.
I wouldn't worry about the legs breaking the steering wheel... If anything, its the legs that will break. Some people have had to use a 2nd pair of legs due to them breaking. Some wheels come off much easier than others... Mine came off pretty easy and I didn't have to let it sit overnight. I just set up the puller, applied a fair amount of force... yanked on the wheel a bit... applied a little more... tapped on it a little with a hammer and then slowly the wheel began to pull off.
The best tip I can give you is, be ABSOLUTELY sure your J-hooks are seated perfectly. If only a portion of the J is engaged in the notch on the steering wheel, it is more likely to snap. (Picture hanging from the edge of a skycraper while using only two fingers on each hand instead of all four). Don't apply too much force too fast; but if you're careful the legs should take quite a bit of force before they break.
Old May 20, 2010 | 12:11 PM
beaners's Avatar
beaners
If it is that tight. Don't be afraid to smack it with a hammer and it should pop....
Old May 20, 2010 | 12:17 PM
rpm462's Avatar
rpm462
If you do it let me know how it goes...might be attempting it myself in the near future. Did you find some info on how to safely disconnect the airbag?
Old May 20, 2010 | 12:44 PM
Alaskanpilot
I have a pdf file that goes over this (it's instructions for removing the steering wheel). I can send it to you if you PM me an email address!
Old May 20, 2010 | 12:47 PM
Gitusum's Avatar
Gitusum
rikk_t@hotmail.com
Old May 20, 2010 | 12:56 PM
Alaskanpilot
you has mail!
Old May 20, 2010 | 01:44 PM
TOOGECKO's Avatar
TOOGECKO
I have done five SW swaps now and if you get the proper tool (Kent Moore) and understand the directions, it is pretty straightforward. This is one of these "do it by the book" procedures due to the risk of deploying the airbag. It is not bad as long as you are certain that you disable and then properly enable the SRS system before and after...
Old May 20, 2010 | 01:47 PM
Greg34's Avatar
Greg34
3rd Gear
+1 on the instructions please
G-
Old May 20, 2010 | 02:28 PM
rpm462's Avatar
rpm462
PM sent...thanks!
To steering wheel puller????
