Installing Exhaust
Old May 20, 2010 | 07:55 PM
chrisj's Avatar
chrisj
St. Jude Donor '12
Default Installing Exhaust
I'm going to be installing a new cat back system soon. Upgrading from my GHL's to B&B's.
When I do the install, do I need new gaskets? I assume I can use the bolts from the old system on the new system, right?
Are there any other parts I may need for the install?
chris
Old May 20, 2010 | 07:58 PM
Hammer99's Avatar
Hammer99
I was able to reuse my gaskets.
Old May 20, 2010 | 08:05 PM
dobewillie's Avatar
dobewillie
I would get new gaskets but thats just me good luck
Old May 20, 2010 | 09:17 PM
jrose7004's Avatar
jrose7004
I bought new.
Old May 20, 2010 | 10:29 PM
Daw9-02Vert's Avatar
Daw9-02Vert
Default Gaskets
Stop by the dealership prior to install and pick up 2 just in case. I Just did this last week installing an aftmkt exhaust. Advanced Auto didn't have them and they recommended the dealership. Have them - don't open them and examine the condition of the gaskets when you remove the exhaust. If they look really good - keep the existing and take back the ones from dealership. They cost me $26 for 2 (not cheap) but mine were good probably because I was going from stock to aftmkt.(first change out) and I only had 12k miles. Your mileage and since they have been changed out already may dictate you to change out. They are a substantial gasket that are pretty solid.
Good luck!
Old May 20, 2010 | 11:26 PM
chrisj's Avatar
chrisj
St. Jude Donor '12
So just the basic exhaust gasket from the dealer? Anyone else get this from a basic auto parts store? I'd rather go to the local O'Reilly than the dealer.
chris
Old May 21, 2010 | 01:49 AM
itzza427's Avatar
itzza427
chris
Yeah,,you get screwed at the dealer,,$12+tax,,,for EACH gasket!! A member posted a while back that he went to Advanced Auto Parts and got Walker gaskets part # 1873,,,for $4 each!! Any store that carries Walker(should be just about all) should have or be able to get them for you!!
Old May 21, 2010 | 06:12 PM
KeyoRacing's Avatar
KeyoRacing
I had mine done and they wanted new gaskets...
Old May 21, 2010 | 09:47 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
2 gaskets come with the system. And you can use your stock bolts no problem.
Old May 23, 2010 | 12:07 AM
chrisj's Avatar
chrisj
St. Jude Donor '12
Local O'Reilly and Advance Auto didn't have them. Both said I'd have to head to the dealer. My closest dealer is closed Sat. May just be reusing the old ones. I wanted to have the new ones handy just in case they were needed.
Thanks for the info everyone.
chris
Old May 23, 2010 | 03:22 AM
mel3535's Avatar
mel3535
i [aid like 6 bucks for new gaskets at kragen, and everything else should be a simple swap
Old May 23, 2010 | 08:35 AM
rws.1's Avatar
rws.1
I paid under a dollar each for my gaskets at Advance auto... the photo of the part with number is athome, but search under my id... i have posted it several times before...
Old May 23, 2010 | 02:32 PM
mel3535's Avatar
mel3535
kragen PN EG24685
Old May 23, 2010 | 06:01 PM
When I installed a set of B&Bs on my '00, I just reused the stock gaskets and they worked just fine. I guess it would depend on how many miles are on your car - for the few dollars it costs to get new ones, you might just want to get them and not have to worry about it.
Old May 23, 2010 | 06:06 PM
thechosenone's Avatar
thechosenone
Just get new ones and be done with it, it would suck if you got a small leak b/c you are running old ones down the road. Better safe than sorry.
To Installing Exhaust
