Removing wheel clear coat?
Old May 21, 2010 | 03:56 PM
chill99's Avatar
chill99
Default Removing wheel clear coat?
Long story short, I have some clear coat issues with a couple of wheels. My local wheel & tire guy, who I trust, recommended that I have the clear coat removed and the wheels polished by a place in town that specializes in that sort of thing.
Is removing the clear coat a good idea? Will I have long term issues with the wheels? Harder to clean?
BTW, I'm talking about OEM chrome aluminum 5 spoke wheels on my 2004 C5 convertible.
Thanks in advance,
Old May 21, 2010 | 04:09 PM
hotwheels57's Avatar
hotwheels57
Thanks in advance,
Are they just clear coated oem polished aluminum or are they clear coated oem chrome? The latter would be a little odd.
You can remove the clear coat from polished wheels, keep them polished with just a little regular polishing routine and maintain them looking as new. That's how many after market high end wheels come. They're not clear coated. They will require preventative maintenance to keep them from oxidizing though. A good polish like WENOL is easy to apply and buff off. Or there's those polishing ***** from MOTHER'S.
If you remove the clear coat from "chrome aluminum", you have just chrome. Again, I'll say that would be a little odd. But, if you really have a clear coat over chrome, then you'll just have chrome plated wheels. They still need a routine maintenance to keep them looking good.
Old May 21, 2010 | 04:25 PM
dougbfresh's Avatar
dougbfresh
Remove the clear and have them powdercoated clear-much better than stock.
Old May 21, 2010 | 04:26 PM
stevenm357's Avatar
stevenm357
I did it to my 2000 WS6 wheels, if you keep it in a garage or polish regularly it's no problem, but if you let them sit outside for a winter... time to completely re polish them.
Old May 21, 2010 | 04:32 PM
chill99's Avatar
chill99
Hmmm... I guess I don't really know the answer to that. But I do know for a fact they are clear coated. Thanks for the reply.
Old May 21, 2010 | 04:34 PM
chill99's Avatar
chill99
Is the purpose of this for maintenance, looks, protection, or all of those?
Old May 21, 2010 | 04:45 PM
03WhiteConv's Avatar
03WhiteConv
See if you can find a good body/paint shop and have then re-cleared after polishing. Then you can care for them just like any other painted surface.
Thanks in advance,
Old May 21, 2010 | 04:47 PM
hotwheels57
A powder coated clear coat will be much more durable than painted clear coat. You've probably seen painted clear coat wheels that actually have no clear coat left on them. Climate, UV rays, incorrect wheel cleaners, harsh soap cleaning, chemical degradation will eventually remove/damage a painted clear coat. Many manufacturers use it though because it's less expensive.
With clear powder coat, once the wheel surface is polished, it'll remain that way unless the clear powder coat is somehow damaged or chemically degraded. It's more chip resistant than clear paint coat.
Old May 21, 2010 | 04:50 PM
chill99's Avatar
chill99
I assume my normal autobody shop would be the best suited to do this?
Old May 21, 2010 | 04:55 PM
hotwheels57
Not sure which manner you're referring to? A body shop can strip the original painted clear coat, but maybe not be capable of re-polishing the aluminum before they apply a new painted clear coat.
A body shop probably will not be set up to clear powder coat your wheels though. For that, you need a powder coating shop. And you should get references for powder coating shops. Some may be good at powder coating your chain link fence, but not for your wheels.
You should consider having the wheels re-polished before you try either manner.
You might contact CALCHROME which has the ability to perform all types of wheel restoration, polishing, chrome, etc. They may have a set of your wheels in stock on an exchange basis. If not, they can re-finish your wheels in whatever you want...
http://www.calchrome.com/calchrome_custom.php
Old May 21, 2010 | 05:27 PM
kerryt1's Avatar
kerryt1
If it's clear coat, use aircraft stripper. It's made for removing paint from aluminum, but will not work on chrome.
Re-polish, then have them cleared again (paint or powder).
Old May 21, 2010 | 05:47 PM
hotwheels57
If you post some clear images, it should be relatively easy to tell if they're oem polished aluminum or possibly chrome plated.
My bet is they're oem polished aluminum wheels...
Old May 21, 2010 | 05:51 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Default Speaking from experience...
Personally, I've never clear coated polished aluminum and I never will. It takes a little away from the character/glow of perfectly polished metal.
If you're going to drive the car on rainy days the finish will deterorate over time, but for the simple maintenance just get a Mothers Powerball and a drill. Hit the wheels once every 2-3 months and they'll stay pristine.
If the car never sees rain you can go two years without retouching.
Old May 21, 2010 | 09:47 PM
Jistari's Avatar
Jistari
Dont mind Josh there He is currrently hand polishing every single part of his engine (see avatar), so having to keep non clear coated wheels seems like a vacation to him
If you want to keep them (because it may be cheaper to just buy a set of used wheels in good shape) I'd strip em, have them polished by someone who knows how, and then re cleared.
I didnt even know we had "clear power coating"? That the same thing (goes in the oven)? Must be nice.
Old May 22, 2010 | 08:04 AM
wfdlt8's Avatar
wfdlt8
I stripped mine with airplane stripper and polished them by hand and they look a lot better. The wheels have more of a shine almost like chrome. This is a job though, the factory clear coat is as tough as nails and will take several coats of airplane stripper and some hand scrubbing with a non scratching scrubbing pad to remove it. It took me the better part of two days to do this. I think the final result was worth it though. Do not try this with normal paint stripper it will not even phase the clear coat, buy the good airplane stripper it is well worth it.
Old May 22, 2010 | 08:49 AM
rws.1's Avatar
rws.1
Get the highest content methylene choride paint stripper you can find at Lowes/Home Depot etc.
look for a post by or PM C5 Naples... he hand polished his wheels after stripping them. They are incredible.
a professional metal polishing shop will likely charge you $75-$100 per wheel for polishing them.
Old May 22, 2010 | 04:22 PM
The real benefit of the clear coat, besides protecting the wheel, is that you don't have to keep polishing the raw aluminum to keep it looking good. Take the clear off, and you will need to polish the wheels to keep them looking very good. If you don't mind that extra work, then just leave the clear off. Me - I think I would want the clear on.
To Removing wheel clear coat?
Old May 22, 2010 | 04:28 PM
hotwheels57
It depends on an individuals desire/discipline to continuously polish the aluminum...
Old May 22, 2010 | 04:31 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I use to polish motorcycle rims, the best and only stuff to use to remove clear coat FAST is aviation grade stripper. This stuff is super toxic, so wear gloves, and not rubber gloves either, it'll eat right through them. Once done, give the rims a good bath to remove any exccess material. Polish the rims then use zoopseal. zoopseal is similar to a clearcoat. It basically protects the rim from the elements and makes it easier to clean.
Old May 22, 2010 | 04:34 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
great post. my wheels are in rough shape and this will be a winter project for me...eventually let us know what you decide and some before and after pics too
I am going to take your suggestion. I've seen your pics and what you do with metal so I'm on board. thanks for the tips
This saves me asking what type of stripper to get
