wheel bearing
Old May 22, 2010 | 06:44 PM
Dave concrete's Avatar
Dave concrete
Default wheel bearing
I'm hearing a hum or whine in rear of car. What is a good way to check for a bad wheel bearing? The faster you go the worse it gets. It almost puts out a bit of drone.
Old May 22, 2010 | 08:53 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Its the wheel bearing!
I tried the 12-6 and 9-3 wobble the tire method but once I took the wheel off and spun the bearing by hand you could feel the harshness compared to the new timken.
I replaced both rears and then the fronts shortly after.
Rears took me 2 hrs in my driveway fronts where a 30 minute job.
My car rides smooth and no noise!
Mario
Old May 22, 2010 | 10:05 PM
tbiker99's Avatar
tbiker99
Mario
If you don't mind, what did those bearings cost? I've got a whine that's kind of bothered me, it only really happens at highway speeds, and when I am at steady throttle.
thanks
Old May 23, 2010 | 02:48 AM
Last C5's Avatar
Last C5
thanks
If it whines when you're under throttle and stops when you let up on the throttle - it sounds like a rear end going to me.
Old May 23, 2010 | 05:47 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Yep, and if the sound changes when turning, it's more then likely the bearings...
Old May 23, 2010 | 08:32 AM
Chevy-SS's Avatar
Chevy-SS
Are you saying the 'wobble' test did not show anything?
How many miles on your car?
thanks
To wheel bearing
