DRL's Not Working!!!
May 24, 2010 | 12:57 AM
Hi my 2003 Z06's DRL's are not Working!
Also I noticed in the DIC options when I put "Twilight ON" the lights pop up even if its day time?!!?
What do you guys think the problem is?
Thanx
May 24, 2010 | 01:49 AM
First thing to check is whether the A2 fuse is fitted. Could a previous owner have pulled the fuse? It would inhibit the DRLs.
May 24, 2010 | 01:55 AM
Cruise-In VIII Veteran
St. Jude Donor '07
I pull my #2 fuse and that would be my first check. Maybe a bad fuse or no fuse. Check your codes, I believe it is BCM 0502/0507 codes that are thrown when the fuse is pulled. Maybe it sends a signal when it is bad also.
As for the headlights...I turn my TWILIGHT OFF, I am not a fan of the car trying to do things that I like to control.
May 24, 2010 | 06:05 AM
In the DIC, your approach lights should be "on".
May 24, 2010 | 07:42 AM
Quote:
Originally Posted by
SCM_Crash
They r on
May 24, 2010 | 08:24 AM
Is the sensor on the top of the dash obstructed so that the car thinks it's dark? If not, maybe the sensor has gone out.
May 24, 2010 | 03:03 PM
Do you have the relay mod? Check to see if ~38 and #40 are fitted footwell panel). If there are jumpers fitted maybe the relay mod was done.
May 29, 2010 | 05:37 AM
65GGvert
Does anyone know the part # for the light sensor?
May 29, 2010 | 10:59 AM
Got the part number
12450121 Daytime running lamp ambient light sensor.
Anyone know how i can have the DRLs on all the time even at night?
Is there a way to trick the car to think it is daytime even at night?
Thanx
May 29, 2010 | 11:10 AM
C6-Stingray
I'd say they fixed themselves then
May 31, 2010 | 03:54 AM
May 31, 2010 | 02:40 PM
May 31, 2010 | 03:03 PM
C6-Stingray
Thanx
Just take the sensor out of the circuit. Light sets a voltage IIRC.
May 31, 2010 | 03:07 PM
i for one dont like the twilight..dont know how good they work on the vette,but on my 66 caddy the were a PITA...i would turn the lights on and they would go back off for about a minute before they would come back on..
Jun 1, 2010 | 05:34 AM
DeeGee
Will the car then think that it is day all the time and have the DRLs on even at night?
2002 ,
avic ,
c5 ,
canadian ,
corvette ,
d3 ,
daytime ,
drl ,
light ,
lights ,
runing ,
running ,
sensor ,
stopped ,
turn ,
twilight ,
working
