problems with my A/C on my C5
Old May 26, 2010 | 11:45 AM
nmateo's Avatar
nmateo
Cruising
Default problems with my A/C on my C5
Hello all,
I have a 1997 Corvette with 52000ml. My A/C has always worked great until now. I try turning it on and the light is flashing but no a/c. I drove it for a bit and the a/c light came on but no cold air. I can hear the compressor wanting to click on but nothing happened. Then the A/C light when off. I am guessing is low freon but i wanted to get all your suggestions. Also my screen in my A/C unit is really dim and i can only see it at night. Please Advice.
Thanks.
Old May 26, 2010 | 11:52 AM
nkx1's Avatar
nkx1
Originally Posted by nmateo
Hello all,
Thanks.
I'm sure others will chime in with helpful advice... Not sure if this is helpful or not, but I had the exact same problem with my Toyota Solara. According to the Toyota dealer that fixed it, the problem was a disconnected ground wire.
Regarding the light issue, you will probably need a new HVAC unit or to replace the LEDs backlighting.
Old May 26, 2010 | 11:56 AM
Jewjenk's Avatar
Jewjenk
First things first.
Did you check to see that you have Freon?
This would be the common sense thing.
Old May 26, 2010 | 01:15 PM
jgarrett's Avatar
jgarrett
If the unit gets low on freon, the compressor will sometimes shut down in order to avoid damage.Mine was doing the same thing and I also have a 97.I unplugged the battery cable for about 10 minutes that will usually reset the compressor then I added freon and now she sits on 40 deg
Old May 26, 2010 | 01:21 PM
BillY2KFRC's Avatar
BillY2KFRC
Mine did the exact same thing last year and just needed freon.
Old May 26, 2010 | 02:40 PM
dougbfresh's Avatar
dougbfresh
Get manifold guages on it and then report back.
Old May 26, 2010 | 03:20 PM
SaberD's Avatar
SaberD
the ac compressor will not turn on and the ac light on the button flashes when you are low on freon. there is a leak in the system somewhere. freon does not just disappear into nowhere without there being a leak somewhere. charge it with freon that has UV dye so you can spot the leak. replace the gasket or o-ring at that location and recharge it again. good luck!
Old May 26, 2010 | 07:59 PM
bighank's Avatar
bighank
Default Freon can leak might have leaks at joints or schrader valves
Some freon loss can happen as it can permeate any loose connection or if the compressor seals are starting to go. One of my schrader valve fittings (where you connect the HI and LO pressure hoses) was leaking ever so slightly. I got new spring loaded valves (look like inserts in tire valves but are made to take freon and high pressure) and replaced them along with the orfice tube in the HI pressure line when doing work on the AC. Check all connections as over time and due to changes in temperature they can leak ever so slightly. Sometimes just tightning them can seal the leak without having to replace the O rings.
I agree you are probably low on freon. If you can't run compressor when trying to add freon on the LO side simply jump out the LO pressure cut out switch to get the compressor to run.
Old May 26, 2010 | 08:11 PM
jrose7004's Avatar
jrose7004
I'd think that it has a freon leak and is low on freon.
Old May 26, 2010 | 08:15 PM
RSchleder's Avatar
RSchleder
Freon leak
Old May 26, 2010 | 10:34 PM
Carcass's Avatar
Carcass
So,once you get the freon situation squared away,you can tackle the dim display:
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old May 27, 2010 | 06:54 PM
nmateo's Avatar
nmateo
Cruising
thanks for all the replies. Today after work i unplugged the black cap that runs on the a/c line by the batter and noticed bubbles coming out. Can that possibly be a point where it is leaking? my car sat all winter and the a/c ran perfectly last summer. I am going to go to auto zone to buy the freon charge, is there anything else expect that and the dye i need to get?
Old May 28, 2010 | 12:29 AM
snooks's Avatar
snooks
Default A/c problems c-5
Hello all,
Thanks.
Have 1999 hardtop 6-spd at 50,250 miles a/c stopped cooling. Freon charge was low. Car ten years old at the time and will have inherent slow freon leakage at hose connections and/or compressor; charged it up and now a year later still cooling as good as new. Very cold air; on high speed will get too cold in cabin.
Old May 28, 2010 | 07:51 AM
ledzephar's Avatar
ledzephar
I have a 2003 and was wondering what kind of PM can be performed to keep the AC system in top shape or should I just don't fix it if it ain't broke.
Old May 28, 2010 | 09:14 AM
dougbfresh's Avatar
dougbfresh
There is no PM.
Old May 28, 2010 | 09:22 AM
kozmatic's Avatar
kozmatic
You bet it is. I had the same problem a few weeks ago. After my AC quit out of nowhere, I went to check the freon pressure, not realizing the stupid AC belt was the problem! Anyway, after just touching that valve stem, it started leaking. Bubbles are freon in liquid form escaping. You can get a valve stem replacement kit for like $5 at any auto parts store.
Old May 28, 2010 | 09:36 AM
dougbfresh's Avatar
dougbfresh
BUT, as soon as you try to service this won't you let all the refrigerant out?
Old May 28, 2010 | 10:40 AM
kozmatic's Avatar
kozmatic
Yeah, if there's any even left in the system.
Old May 28, 2010 | 05:55 PM
jgarrett's Avatar
jgarrett
I replaced my schrader valve with the system charged,I don't recommend doing it that way but after charging my system I noticed that my valve was leaking so I pulled up on it with some needle nose pliers and I couldn't hear it leaking anymore.A/C cooled down to 40 deg,But by the next morning car no makey cool air.So I threw on my gauges and charged it again preparing to set out to find the leak, which I found when removing the low side hose.Valve had continued to leak despite being pulled out until I didnt hear it anymore.I had another valve and 2 valve wrenches so I pulled one and immediately jabbed the other in and tightened,This is the 2nd summer and A/C is still ice cold so I assume my loss was minimal.But a simple soap test could have saved me lots of effort.
To problems with my A/C on my C5
