[Z06] Performance upgrade suggestions?
Old May 28, 2010 | 03:12 PM
pechetr's Avatar
pechetr
Default Performance upgrade suggestions?
Just picked up a mint 2004 Z06 TR that is bone stock. I want to get some feedback on performance upgrades from some of the members. First of all....will removing the cats on the factory system improve the sound/power at all? She's a little quiet for my liking but I don't want it too loud either. Second, is their significant gains by going to headers vs the stock TI system? I like the weight savings with the TI. Third, By adding a Blackwing and possibly headers to the factory Catback, what kind of gains could be expected from a professional tune? Fourth, Any advantages to porting the intake and TB or is it best to go with an aftermarket TB and intake (eg. FAST). I have heard about big gains from a cam swap, but all I have read here basically says that to get the full effect of the cam, you need to upgrade the intake and exhaust. I would rather stick to bolt ons if possible. I am not necessarily on a budget, but not a millionaire either. I am looking to get about 400 rwhp overall. I guess I want to know what is the easiest/reasonably priced options to get to that 400 rwhp mark? I am sure these questions have been asked a thousand times here, but I can't seem to find a thread on it....Any help will be greatly appreciated.
Old May 28, 2010 | 10:26 PM
Kmcoldcars's Avatar
Kmcoldcars
I have a 2002 Z06 with long tube headers, high flow cats and Borla exhaust and a tune. It makes about 375 RWHP. My understanding is that the long tube headers give about 25 HP max, and the Borla gives about 1 HP and the sound. I have read that there is no advantage to replacing the factory cats and titanium exhaust, other than sound. A better intake (Vararam) will give more power on the road but will not show much on a dyno. Improving the intake and TB should give some more gains. The larger gains come from a cam and heads or supercharger or turbos. However, without going there you should be able to get to 400 RWHP with bolt ons..
Old May 29, 2010 | 01:07 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Honestly, wouldn't bother upgrading the LS6 intake. It flows nicely and for the money you spend on the fast, I don't think it is worth the gains you see.
If the car does not have a short throw shifter in it, that is a great mod, nothing in the HP gain areas, but makes it alot more fun to drive.
Congrats on getting your Z, I recently picked up a 2003 Z TR myself and I am trying to achieve the same things you are, but I will be installing a CAM down the road. Due to the lack of tuning options out here in Hawaii, I am not getting to heavy in the modding right now.
Have fun and enjoy your car.
Old May 29, 2010 | 12:18 PM
pechetr's Avatar
pechetr
Thanks guys....Good to know I shouldn't waste the money on a FAST.
Old May 29, 2010 | 02:05 PM
zeevette's Avatar
zeevette
It's not a waste of money at all, it's just the gain per dollar spent is lower than some other mods. There's some misinformation here. To the OP, the stock Ti parts are only in the catback. The exhaust manifolds are cast iron and replacing them with headers loses weight, and increases power. The mid-pipe system is replaced when you buy a complete header system from one of our fine vendors, (I like LG) will also be lighter, and flow better with HF cats, and an included X-pipe will smooth out the sound, reduce popping, and eliminate the H-pipe jingle. If you replace your exhaust system from engine to catback, and retain the stock Ti catback, it will get a little louder with cats, and a little louder yet with an offroad (catless) X-pipe.
Old May 29, 2010 | 02:26 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Where is the misinformation at in the other posts? I didn't see anything misleading.
Old May 29, 2010 | 02:32 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
How about not wasting any money and leave it stock?
Old May 29, 2010 | 02:57 PM
Chris Stewart's Avatar
Chris Stewart
does not compute...
Old May 29, 2010 | 03:14 PM
RIKKITIK's Avatar
RIKKITIK
St. Jude Donor '09
That's just so.........un-Zish!!(just kidding!). There are times I wish I had left mine stock. I've tried to do nothing that can't be undone, and retained/bought all parts needed to return it to stock if I want to later.
To the OP, it's difficult to outflow the Ti catback, so not much to be gained there, other than sound. The CAI, headers, and tune seem to net 375 - 390 hp, (as stated above). Good luck
Old May 29, 2010 | 03:16 PM
MTPZ06's Avatar
MTPZ06
Vararam or Honker CAI, LT headers (catted or uncatted is up to you), and a professional tune is a great starting point; and should get you close to your rwhp goal. Don't get caught up on the number...it's just a number. Focus on making reliable hp that your car can put to the ground, and makes it more enjoyable to drive. Just my opinion...
Old May 29, 2010 | 03:35 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old May 29, 2010 | 06:01 PM
pechetr's Avatar
pechetr
I would like to keep the factory Ti catback. I think Long tubes and an off road x pipe to start, then perhaps a ported TB, add the Blackwing I ordered. 160 degrees stat with TR6 plugs and then a tune. I appreciate the comments guys. Even yours Quick.....
Old May 29, 2010 | 06:07 PM
jonnyc's Avatar
jonnyc
this is the first mods anyone should start with.i would add a shaner ported throttle body to this list.i wouldn't do a fast intake unless you are planing on a huge cam and high rpm power band motor.
after doing these,if you want more power and decide to put a cam in,you'll already have the supporting mods done.when doing a cam change there are other things you will want to do/need.you'll need to get a cam kit,which should have new springs,retainers,locks.you'll also need pushrods,head gaskets,head bolts,and crank bolt.probably want a new timing chain,ported oil pump,and underdrive pulley.
i always recommend a two piece timing cover.that way if you ever change your mind on the cam,it becomes a whole lot easier job to change it.
Old May 29, 2010 | 07:56 PM
ls2alex's Avatar
ls2alex
headers and tune is the best way to start
Old May 29, 2010 | 09:37 PM
RedZMonte's Avatar
RedZMonte
Much gain from a good set of Rockers? Traditionally a simple mod without tearing into the motor for Cam/Heads and with other mods listed will be reliable and should put you i would think to the 400hp mark.
S
Old May 29, 2010 | 10:08 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Unless you are going FI down the road, I wouldn't do TR6 spark plugs. Really not much gained there.
Old May 29, 2010 | 10:40 PM
TXGS507's Avatar
TXGS507
Old May 29, 2010 | 10:45 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Originally Posted by 0H1Z06
To Performance upgrade suggestions?
