grrr....steering rack "exploded view" picture
Old May 30, 2010 | 09:37 PM
Had20z's Avatar
Had20z
Default grrr....steering rack "exploded view" picture
Just like the title says, i found a the pic on my iphone but now that im at a computer to print the pic i cant find it!
any help??
Old May 30, 2010 | 10:52 PM
Bill Vett's Avatar
Bill Vett
PM DeeGee, he lives in England so it will take a few hours due to the time zone he's in.
Old May 30, 2010 | 10:54 PM
Forum member Patches may also have a pic for you. PM him and ask.
Old May 30, 2010 | 10:59 PM
zagger's Avatar
zagger
(1)Lubrication Fitting(2)Hexagon Slotted Nut(3)Cotter Pin(4)Tie Rod Seal(5)Outer Tie Rod(6)Hexagon Jam Nut(7)Tie Rod End Clamp(8)Rack and Pinion Boot(9)Large Boot Retaining Clamp(10)Inner Tie Rod(11)Adjuster Plug Lock Nut(12)Shock Dampener Ring(13)Mounting Bracket Assembly(14)Mounting Grommet(15)Cylinder Line (LH)(16)Cylinder Line (RH)(17)O-ring Seal(18)O-ring Seal(19)Rack and Pinion Gear Assembly (Partial)(20)Dust Cover(21)Shock Dampener Ring(22)Inner Tie Rod(23)Breather Tube(24)Large Boot Retaining Clamp(25)Rack and Pinion Boot(26)Tie Rod End Clamp(27)Hexagon Jam Nut(28)Outer Tie Rod(29)Cotter Pin(30)Hexagon Slotted Nut(31)Tie Rod Seal(32)Lubrication Fitting
Is this what you were looking for?
Old May 30, 2010 | 11:14 PM
Bill Vett's Avatar
Bill Vett
Just two red x's
Old May 30, 2010 | 11:30 PM
Munch's Avatar
Munch
St. Jude Donor '10
This?
Old May 30, 2010 | 11:32 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Links to your local PC won't work.
Old May 31, 2010 | 12:00 AM
zagger's Avatar
zagger
LoL, still learning, thanks
To grrr....steering rack "exploded view" picture
